Results 1 to 5 of 5
    Shimano "Optislick" cables
    Time to stock up on shifter cables.
    When I got a new frame a couple years ago I had what I believe was a DA 9000 Cable kit put on.
    Worked fine but the cables had what I'd describe as little string wrapped around it and that eventually gets lose in the shifter. Not really a problem but it bugs me anyway.
    When I buy a stock of replacement inner shifter cables I want to make sure I DO NOT get those.
    Am I correct that the "Optislick" inners are just normal decent cables and not the ones coated with that crap that comes off?
    Thanks,
    Reputation: Lombard's Avatar
    May 2014
    From what I can see, "Optislick" is a coating. I have no idea what Shimano means by "electrically coated layer". More info here:
    https://bike.shimano.com/en-EU/techn...optislick.html
    https://www.amazon.com/Shimano-Shift.../dp/B01N3OWFG2
    I would certainly be interested in what others here have to say..
    yeah I know it's a coating but just want to make sure it's not that stringy crap that comes off.
    The last of my supply that I bought a few years ago and don't have that crap say "sil-tech". But that seems to be outdated terminology.
    I could just get Jagwire rather than trouble myself with this terminology (have used those and shimano in the past and they seem to work about the same to me) but I like spending $9 more than $15.
    May 2014
    Personally, I would stick with plain Jane stainless steel and skip any coatings. Don't know if Shimano still makes any "naked" stainless steel cables. I don't think there's anything wrong with Jagwire either.
  1. Replies: 5
    Last Post: 09-14-2014, 04:31 PM
  2. Road Cables vs. Mtb Cables...do both fit on RB?
    By wannaberoadie in forum Components, Wrenching
    Last Post: 02-05-2012, 06:25 AM
  3. $2 Cables vs. $5 cables and 5mm vs 4mm housing
    By tjanson in forum Cyclocross
    Last Post: 08-05-2009, 01:20 PM
  4. Brake cables or dr. cables; Campy or Shimano
    By OperaLover in forum Components, Wrenching
    Last Post: 12-23-2008, 10:21 AM
  5. Cables vs. cables
    By johndengler in forum Components, Wrenching
    Last Post: 03-12-2006, 01:50 PM
