Results 1 to 8 of 8
    Apr 2013
    Shimano STI Brake Housing Ferrule?
    I decided to replace the stock cable inner/outers after a number of years (STI 105-5700). They had metal ferrules on the shifter end which were stuck in the shifter so I had to yank out the cables, but the ferrules seem to have fused to the plastic, are completely unremovable. Needlenose pliers did absolutely nothing because there is nothing to grab onto, so I had to start breaking up the ferrule.
    After almost two hours with an awl, I've scraped most of the ferrule but there are bits in there deep that probably won't ever come out. My question is: is a ferrule needed at the shifter end for the brake cable to work properly without fraying or causing a safety issue?
    Because if one is needed, looks like I'll need new shifters.
    I have a mind to shoot the clown who installed this cabling.
    'brifter' is a lame word.
    No, Shimano shifters don't require ferrules on that end of the brake housing. Whether they're needed on the frame end is dependent on the frame.
    I work for some bike racers
    and a bunch of skateboards
    Forever a Student
    Mar 2014
    Must have been a chore to get ferrules in there.
    They don't fit normally.
    This strikes me as a case of a lazy mechanic who thinks they know it all because they did a thing once.
    use a torque wrench
    That's what I was thinking. Like the last shifter the guy worked on was SRAM...'oh yeah, I need ferrules here'.
    Apr 2013
    Thanks! So assuming the cable hole is clear, no major jagged edges from the old ferrule, if I jam the Shimano cable in there I should be good to go? My secret fear is that my brake cable will fray and snap as I'm coasting down a hill at 25 mph.
    Quote Originally Posted by Mad Cow Disease View Post
    If there's something in there that would damage the cable I'd hope you feel it.
    Reputation: Lombard's Avatar
    May 2014
    Highly unlikely. Cables generally don't snap suddenly without fraying first. As individual strands of wire break, your brake pull would noticeably increase.
    This is much more likely to happen with Shimano shifter cables than with brake cables as the shifter wraps and unwraps the shifter cable as you shift.
    And as CX said, if there were something in there abrading your brake cable, you would most likely feel it as you are pulling the brake.
    -- Warren Buffett
    Reputation: Kontact's Avatar
    Apr 2011
    The real danger is that the housing won't fit in all the way, but feel like it has because it is up against whatever junk is still stuck in the lever body. Then you go to brake hard and the housing crushes he rest of the way in creating a bunch of extra slack in the cable.
    It would have been better to leave the old ferrule in place, but just make sure the bottom of the hole is clean and flat so the housing has something stable to seat against.
  1. When to use a brake ferrule tongue?
    By k9taxi in forum Components, Wrenching
    Last Post: 05-23-2015, 12:25 PM
  2. Brake Ferrule stuck...
    By xeon in forum Components, Wrenching
    Last Post: 06-16-2014, 10:49 AM
  3. Need for cable cap/ferrule on brake cable?
    By DaveG in forum Components, Wrenching
    Last Post: 09-27-2012, 12:59 PM
  4. how can ferrule be removed from end of cable housing?
    By pdxtim in forum Components, Wrenching
    Last Post: 01-17-2010, 08:51 AM
  5. rusted stuck brake cable ferrule
    Last Post: 06-04-2007, 05:54 PM
