Results 1 to 5 of 5
    Mar 2013
    Question Shimano Ultegra 6700 GLOSSY GREY group set with SRAM Force GXP 10-Speed Road Crankset
    I'm planning to use a Sram Force 10 speed crankset with Shimano Ultegra 6700 GLOSSY GREY group set. The Sram has black arm/spider and greyish chaining.
    Or another option is Shimano 105 crankset in black. It is a little heavier but better looking than Ultegra or Dura Ace.
    Does it look fine or odd when using different brand crankset ???
    Is it OK to mix components ?
    Thanks.....
    Not a rocket surgeon.
    Nov 2008
    Looks is up to you. It will work fine though.
    Reputation: PlatyPius's Avatar
    Feb 2009
    Re: Shimano Ultegra 6700 GLOSSY GREY group set with SRAM Force GXP 10-Speed
    Quote Originally Posted by tihsepa View Post
    Is it fine if I eat mac & cheese with my steak instead of mashed taters? Is it okay if I wear brown shoes instead of black? I pee standing up; is that okay?
    Other countries need to stop hatin' or we'll unfriend them. - Christine
    Apparently I left my reading comprehension glasses in my ass. - DrRoebuck
    Still, it felt great and I felt like I was sitting on some kind of vibrator -Touch0Gray
    Reputation: rbart4506's Avatar
    Aug 2004
    It'll work fine...
    I'm currently running full Ultegra 6700 and a compact SRAM S975 Quarq crankset. Everything works fine with one caveat. With the Ultegra compact crank i could sit in the 34 and run the entire rear cassette without the chain hitting the shift ramps on the big ring. That is not the case with the SRAM I start having issues on the 2nd last cog and the last one is a no go. I realize these are not the best gears to be in, but it does happen and with the SRAM it forces a shift. Not a huge problem though on most ride, moreso when I'm in recovery mode.
    Nov 2008
    Quote Originally Posted by PlatyPius View Post
    Is it fine if I eat mac & cheese with my steak instead of mashed taters? No Is it okay if I wear brown shoes instead of black? Only if they have carbon soles I pee standing up; is that okay? No, handstand only.
    There. Happy?
  1. SRAM Rival or Force FD with Ultegra 6700 Crankset Compatibilty?
    By zone5 in forum Components, Wrenching
    Last Post: 09-07-2012, 05:14 AM
  2. Sram Force or 6700 Ultegra for caad9
    By spettenati in forum Components, Wrenching
    Last Post: 04-27-2012, 07:59 AM
  3. Replies: 20
    Last Post: 06-21-2011, 08:24 PM
  4. Ultegra 6700 vs. SRAM Force
    By Para8291 in forum Components, Wrenching
    Last Post: 02-25-2011, 05:46 PM
  5. Should I go Ultegra 6700 To SRAM Force?
    By SimonChik in forum Components, Wrenching
    Last Post: 09-26-2010, 04:36 AM
Sea Otter Classic
Contest
