Results 1 to 25 of 32
    Banned forever.....or not
    Aug 2002
    The Silca Pista is back.
    Just saw that Silca is bringing back it's old Pista Track pump. Not the $500 one for crazy people, but the old standard steel one. Since I bought mine, on sale, in the mid 80's for $29, the new price seems a little high...$116.
    https://silca.cc/products/pista-floor-pump-1
    Dogbert.
    I>U
    What the Hell is going on
    Reputation: JaeP's Avatar
    Mar 2002
    Quote Originally Posted by MR_GRUMPY View Post
    My older Pista Track pump has the longer, wider handle. That new one has a handle from the standard Silca floor pump. Good luck trying to get high PSI with that little knob. What a rip.
    You'd think we were here for something other than fun. - Ishmael
    Reputation: velodog's Avatar
    Sep 2007
    Quote Originally Posted by JaeP View Post
    High PSI is so Old Skool.
    Too old to ride plastic
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Their pumps are selling based on brand name... That being said, their seat roll looks like a nice bit of kit. Ordered one of their phone wallets for myself...
    https://silca.cc/collections/packs
    That being said...An item purchased in 1980 for $29 would be $90USD in 2017 simply based on inflation.
    Inflation Calculator | Find US Dollar's Value from 1913-2017
    Apr 2011
    The foot is so narrow that the pump tips over easily. I was hoping that they would at least put triangular foot...
    The Silca Pista is back.-pista_base_e0a800c3-66c8-44ee-b51d-4cab29c2ddbd_2048x2048.jpg
    Jun 2006
    I am happy to see this
    I have one from the about 1992. I have used the heck out of it, and only have had to replace the leather washer twice (super easy to do). Other than that, it just keeps on going.
    I am very happy to see they are making it again. The new ones seem to have a few improvements like a bigger more accurate PSI gauge, and a better chuck. Glad to see them back, and better than ever!
    Regarding getting high PSI, I never had an issue when that was the thing, and mine has the small handle. Last pump anyone will ever have to buy.
    hfc
    hfc is offline
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    I never knew they were gone until I just started researching a new pump. My Blackburn died after 15 years and looked into a Silca. I was tempted by he Molteni Orange but ended up buying a white NOS one off flea bay. It has a triangular base on it.
    Feb 2005
    I never understood the issue people have with using a Silca pump. The picture on the web site shows proper procedure. If you need to, You can always brace the pump against your shin but one handed operation is easy. Back in the day it was not a problem to get 120+ PSI. I still use my first Silca from 1979. I also have a Super Pista with the triangular base but I prefer the older one. If either of my pumps die, I will get a another Silca, but I will probably go first.
    Aug 2002
    The only time you should go over 110 psi is if you are riding on 19-20mm tires, or if you are on the track on continental track tubulars........Maybe the price will drop to $90 if it goes on sale.....The old Super Pista was a little taller and had the larger wood handle....Back then, it was $10 more. ($10 was a lot of money back then.....(You could buy a Vittoria CX for $23)
    Dogbert.
    I>U
    Mar 2002
    After a long absence from the track racing I've decided to go back to the velodrome. My local velodrome (Sandy Eggo) just got a its track resurface. The larger wooden handle makes pumping high PSI much easier. I've got a set of Vitoria Corsa EVO-CX that can go to 240 PSI.
    hfc
    hfc is offline
    Jan 2003
    I guess that's why they call it the Pista
    Nov 2009
    He said mid 80s. I did 1985 and it's about $66. So at $120 it's gone up about 90%.
    Sent from my XT1049 using Tapatalk
    Sep 2011
    Does anyone know where you can get wider handles for the older Pista and Superpista? I always found them a fraction narrow.
    Nov 2002
    I've got an old one in my garage. I think it's a POS and it doesn't get used.
    Sep 2011
    The Silca pump head is a POS. Always was. Its fundamental failure is the lack of a pressure release valve. I change mine to Hirame heads. Nothing better than a Hirame.
    Russian Troll Farmer
    Sep 2016
    Seriously? $120 for a pump we all thought was kinda junky back in the 80's? What's next; bringing back the Chevy citation?
    "L'enfer, c'est les autres"
    Jan 2005
    Quote Originally Posted by no time toulouse View Post
    seriously? $120 for a pump we all thought was kinda junky back in the 80's? What's next; bringing back the chevy citation?
    ladies and gentlemen, the 2019...yugo!
    Nov 2002
    Quote Originally Posted by laager View Post
    Funny you should say that. A few years ago I went to the handmade bike show in Sacramento and mentioned that to the owner of Silca. He looked at me with a puzzled look so he obviously didn't get it. Jobst Brandt mentioned a mod he did on his homemade pump with a Silca head that did just that.
    Aug 2002
    I've never had a problem with my Silca. I love the original presta pump head. I had to replace the pump head gasket every 2-3 years until I started using tubes without valve threads. Not sure why you would want or need a pressure release valve. Just pull the chuck off of the presta valve.
    Dogbert.
    I>U
    Nov 2002
    First, it makes it a lot easier to remove the head. Second, it saves the gasket.
    Sep 2007
    I agree with MR_GRUMPY here, smooth valve stems = no issue.
    Nov 2002
    Smooth valve stem tubes are hard to find. I don't think tubeless stems are even offered unthreaded. I'm also not about to retrofit the 8 bikes I own to fit an antiquated pump either. To be fair though, Silca improved the head gasket so it has a much longer wear life.
    Sep 2007
    Michelin tubes, smooth valve stems and easy to find
    https://www.biketiresdirect.com/sear...chelin%20Tubes
    I've got no use for tubeless, so I've no need for tubeless stems of any kind.
    Nov 2002
    I've got Michelin tubes that have threaded valve stems.
    Sep 2007
    I was just pointing out that smooth valve stems are out there and not that difficult to find. Michelin make tubes with schrader valve stems also.
  1. old Silca vs new Silca
    By crankin'along in forum Components, Wrenching
    Last Post: 10-22-2009, 07:33 PM
  2. Silca Super Pista, SKS Rennkompressor or ...?
    By Dutch77 in forum General Cycling Discussion
    Last Post: 08-20-2009, 10:52 AM
  3. Silca Super Pista Floor Pump Repair
    By Bill Silverman in forum Components, Wrenching
    Last Post: 01-04-2009, 08:10 PM
  4. Silca Super Pista Base
    By Scot_Gore in forum Components, Wrenching
    Last Post: 10-31-2005, 06:56 PM
  5. Silca Pista for $15 shipped
    By Nessism in forum Hot Deals
    Last Post: 03-15-2005, 10:21 AM
