Results 1 to 10 of 10
    Apr 2005
    speedplay x/2 pedal rebuild kit question
    How do I get the old black bodies off my speedplay x/2 pedals so I can install the new bodies and bearings that come with the rebuild kit?
    bill
    Jun 2003
    Quote Originally Posted by wiles
    bill
    Go to the Speedplay home page. If you can't find instructions e-mail Speedplay from their site. Their customer service is great.
    Al
    Apr 2005
    The question stands.
    Speedplay home page has nothing I can find about upgrade kits. No descriptions. No instructions. I emailed Speedplay twice over the past 10 days for instructions. Nothing. No response.
    bill
    New Member
    Reputation: divve's Avatar
    May 2002
    It's in the pedal manuals on their website. To remove the body from the axle, take off outer dust cap, insert Torx T-20 driver, loosen axle retainer screw. Then, pull body from axle. Easiest to perform this procedure with the axle still mounted to the crank arm.
    BTW, you got new bodies as well? How does the cost compare to getting new pedals that also include cleats? You also have to take into account that the axle wears due to the center roller bearing.
    Apr 2005
    thanks
    Thanks. Where do I get a Torx T-20 driver? I was only going to buy new bearings until my bike shop offered what they called a complete rebuild option. It cost $60.00 and included new bodies.
    FYI: I can find no pedal manual on the Speedplay site. Maybe you can post the URL for me. The closest I get is the Tech Support page:
    http://www.speedplay.com/index.cfm?f...n=home.support
    which lists a pdf for X1 & X2 Series pedal installation and maintenance.
    This flyer is only one page and has nothing about taking pedals apart or rebuilding them.
    Thanks again,
    bill
    New Member
    May 2002
    That is weird. There used to be PDF documents that contained both the front and back side of the printed manual. Now only the front sides are up on the site.
    You need a T-20 L-Key, a T-handle, or a regular driver handle with a hole through it so you can stick another driver through for leverage. You probably won't be able to loosen the screw with a normal screw driver handle and tighten it sufficiently afterward. The screw is also thread locked from the factory. According to the manual it may require heating with a soldering iron tip in order to facilitate removal. With a proper driver however this shouldn't be necessary.
    I think the most obvious source to attain such a tool would be a hardware store. Alternatively try online at http://www.wihatools.com/indexes/indxtorx.htm.
    New Member
    May 2002
    BTW, apply some Loctite 243 in the axle threads (use a toothpick) and screw before tightening.
    Apr 2005
    Another case of disappearing information in the homeland security age.
    Thanks. If I am successful, I will let you know.
    wiles
    Old, slow, and fat.
    Reputation: MShaw's Avatar
    Jun 2003
    IIRC, its a pretty easy thing to do. Once you get the dust cap off the end, its pretty well self-explanatory.
    M
    I've moved back to NoVA. PLEASE change the weather!
    Apr 2005
    Speedplay tech support finally called me today.
    wiles
  1. Speedplay X/2 vs. X/5
    By bikerdoug in forum Components, Wrenching
    Last Post: 03-30-2005, 10:44 PM
  2. Replies: 54
    Last Post: 10-02-2004, 03:37 AM
  3. speedplay x or zero series pedal debate...
    By joe mudd in forum Components, Wrenching
    Last Post: 09-16-2004, 11:38 PM
  4. Quick question concerning pedal float
    By SPINDAWG in forum General Cycling Discussion
    Last Post: 07-24-2004, 06:54 AM
  5. New to Speedplay Pedals... Question
    By mrrun2fast in forum General Cycling Discussion
    Last Post: 04-14-2004, 12:16 PM
Contest
Tour De France
