Results 1 to 18 of 18
    Reputation: dudigrinfeld's Avatar
    Aug 2010
    Speedplay Zero adjusting question
    I wanted to ask regarding the adjusting float. Which wrench key are you using to turn the 2 adjusting screws on the side of the cleats?
    Also is there any way to adjust the attached / reengage level of the pedal to the cleat or it is a fix things (i mean how easy or hard is to release or attaché the pedal to cleat)
    Thanks for all comments.
    'brifter' is a lame word.
    unless yours are different than the ones i'm holding in my hand right now, it's not a wrench at all...it's a phillips screwdriver that you're looking for.
    there is no way to adjust the engagement tension.they are stiff/tight at first, but break in a bunch after a few rides. follow the instructions, don't overtighten the screws and keep the cleats clean and lubricated.
    2012 Trek Cronus Ultimate w/ SRAM Red Black
    2010 Cervelo T1 sprint bike
    2011 Cervelo P2 pursuit bike
    FMF 24" cruiser
    Bianchi Pista road fixed gear
    1949 Columbia 26" cruiser w/ SRM & fenders...and rust
    '05 Suzuki DRZ400SM
    Aug 2010
    I have zero titanium but I couldn't go in or saw it turn with fillies, do you know size?
    Also where do you lubricant and with what substance?
    Thanks David
    Jun 2011
    Butter works best imho
    FMF 24" cruiser
    '05 Suzuki DRZ400SM
    Reputation: JimP's Avatar
    Dec 2001
    Quote Originally Posted by dudigrinfeld View Post
    Thanks David
    I use a #1 philips for adjustment
    I spray just a little DuPont Multi-Use Lubricant with Teflon on the spring in the cleat every couple of rides. The wear on the cleats is under the outer metal plate where the spring rides.
    Jim Purdy - Mansfield, TX
    Aug 2010
    Is it common to those of you who deal with the Zero to have it difficult to turn the float adjustment screw because it a bit stuck and it grained the screw head? I got a new cleats and 1 out of the 4 screws has this issue not by opening but by turning it inside to minimise the float rate.
    Aug 2011
    I think the threads on the adjustment screws are purposely tight so they dont "self adjust" however, I havent experienced any that wont turn at all, weird...
    Aug 2010
    Quote Originally Posted by mike1217 View Post
    It turned but very difficult and after I believe the thread was a bit damaged. The other 3 turns smoothly without the risk of self movement.
    Aug 2010
    Also is it okay to grease the pedals with lithium base grease or only the Teflon one?
    Jan 2011
    Are you talking about injecting new grease into the pedal or lubing the cleat? These are 2 separate things. Speedplay recommends these:
    -for the pedals - synthetic, waterproof grease
    -for the cleats - dry lube. Do NOT put grease onto your cleats or the outside of the pedals.
    Aug 2010
    Quote Originally Posted by Hughsdad View Post
    Thanks for that. There are so many options do you have any recommended brands? If I Google "synthetic waterproof grease" I get all kinds for suspension, brakes ect.. So I don't know which one and if it will suit for greasing the pedals
    Also for the dry lube can I use any dry oil/lube for chain like "finish line" or
    "TF-2"?
    Jan 2011
    "TF-2"?
    Just go to your LBS and ask for grease for Speedplay pedals and dry lube for the cleats. You'll get a tube of grease that you can use for bearings, threads, etc. as well as the pedals. I use Finish LIne dry lube, but any dry lube should be fine. For the grease, you will also need something to inject it (e.g. a grease gun. Some people use a simple syringe). Read your instructions booklet that came with the pedals on injecting grease, or look it up on SP's site.
    Aug 2010
    Hughsdad,
    When lubing the cleats is it just the spring part that is exposed, as where the cleats sits on soil or it means to unscrew the cleat and to lube the entire metal spring also underneath where it sits?
    Also PTFE dry lube as powder can work the same as oil?
    Thanks david
    Jan 2011
    Just lube the spring where it is exposed. The lube will work in under the spring. I don't know about powder lubes.
    Apr 2004
    I use Liquid Wrench Dry Lube and spray it into upper/lower part of spring, the base and the circular part of cleat. It penetrates pretty much everything. I pretty much do this and the pedal body every day of use. Takes about 2 mins. Stays a lot cleaner than wetter lubes.
    Dec 2008
    I have used Blaster Dry Lube with PTFE for years and it works perfect. About $4 at Home Depot. I have also used Speedplay's own lube which most Speedplay dealers carry and is only about $6.00.
    I use it before every ride because it takes all of about 10 seconds and my Zeros have worked flawlessly for years. I also use the coffee shop covers while walking so that I don't prematurely wear them out or get grass, sand, etc in them..
    Aug 2010
    There is also PTFE Teflon non staining powder lube, I wonder if anyone ever used it for cleats lubrication?
