Results 1 to 8 of 8
    Dec 2004
    Spoke length for straight pull hub in a cyclocross wheel
    I am building a race tubular, disc brake, 28-spoke, 3 cross wheel using an XTR 9020 straight pull, 142 mm, 12-mm thru-axle hub and a Major Tom rim. Itís been a challenge for me to get all the hub measurements, but I collected the required data and input those into the DT spoke length calculator.
    I am having trouble measuring the offset. As near as I can tell it's pretty close to 0, because of the angled nature of the flanges on the hub. By angling the flange, this moves the spoke head closer to the hub center line, possibly even to the center line. Does anyone have experience with this type of a hub and know how to determine spoke offset?
    'brifter' is a lame word.
    28 hole 3 cross? Not 2x? Wasn't that wheel originally 2x?
    I work for some bike racers
    and a bunch of skateboards
    Reputation: Braavos's Avatar
    Oct 2015
    As far as I know the offset parameter is rim hole differ from bead center line. Should be 0 if let me. Nothing about hub's.
    Oh yeah...I was thinking about the 28h/3x thing. The spoke offset has nothing to do w/ the hub, it's a rim thing. If your spoke holes are offset to NDS of the rim, that's the 'offset'.
    Dec 2004
    Bought the hub used. Don't know original setup.
    Dec 2004
    DT spoke calculator only requests a spoke offset with straight pull hubs. Image taken directly from DT website is shown below. The offset indeed seems to refer to the hub. The flanges on a straight pull hub offset the spoke a distance from the hub center line. The offset is to compensate for the thickness of the flange and hence the offset. In the case of this XTR hub, the flanges aren't parallel with the long axis of the hub. The angled nature of the flanges decreases the offset. The offset is typically 2.0 - 2.5 mm for straight pull hubs. However, this doesn't seem appropriate for this hub.
    Spoke length for straight pull hub in a cyclocross wheel-spokeholeoffset.jpg
    Oct 2015
    Quote Originally Posted by mmorra View Post
    In that case measure yourself on two side of nipple flanges and divid it by 2 and you get offset. Should resolve the problem now.
    coaster
    Reputation: Lelandjt's Avatar
    Sep 2008
    It's easier to get the hub specs from the manufacturer than measure it.
  1. 24H Straight Pull DT Swiss Rear Disc Wheel Durability
    By cpark in forum Wheels and Tires
    Last Post: 02-02-2018, 04:14 PM
  2. DT Swiss 350 Straight Pull Rear Spoke Length/Tension issue
    By ybgirnadnerb in forum Wheels and Tires
    Last Post: 02-17-2014, 10:54 AM
  3. how to thread straight pull spoke in hub?
    By stevesbike in forum Wheels and Tires
    Last Post: 01-05-2012, 09:31 AM
  4. Straight pull Aero spoke holder
    By slegros in forum Components, Wrenching
    Last Post: 12-19-2009, 09:17 AM
  5. Spokes, straight pull or 90 degree bend and hub flange.
    By Von Zip in forum Components, Wrenching
    Last Post: 04-25-2004, 04:28 PM
