Results 1 to 2 of 2
    Sep 2008
    Squealing Front Cantilever Brakes
    I am running D/A 7700 shifter/brake lever, Cane Creek SCX-5 Cantis and Swiss Stop combo (salmon/black) pads on a Surly CC for commuting. I had hoped that the Swiss Stop pads would have eliminated the front brake squeal...they didn't. I set the pads so they are toed in exactly right. The more front brake I pull the louder the noise. At this point I would invest in different brakes to get rid of this squeal. Any suggestions? Should I rough up the surface of the pad with sand paper and clean the rim again?
    Reputation: turbomatic73's Avatar
    You could...
    1) Increase the amount of toe-in (you say you've got the toe-in "perfect," but you've still got squealing, so...)
    2) Try reverse toe-in (rear-end of pads strike first)
    3) Try one of these do-dads:
    http://www.amazon.com/Tektro-Brake-H.../dp/B000C14HNS
    Assuming the Surly fork is drilled for the cable stop mentioned in #3. The Tektro do-dad has fixed many squealing/fork shudder issues I've had in the past w/ canti's. It also reduces the amount of toe-in required so you get better performance as well (more power).
    4) Try some mini-v brakes, such as these:
    http://www.amazon.com/ACTION-BRAKE-T.../dp/B001AXXX46
    Click on over to the Cyclocross forum...this topic is covered over & over again
