Results 1 to 8 of 8
    Dec 2014
    SRAM Red Crankset
    I have Pinarello Dogma 65.1 with a SRAM GXP Team Bottom Bracket and I am buying a new Crankset, can I use any SRAM Red 22 crankset with it or do I need to buy specifically a GXP or BB30? Currently I have a SRAM Red 22 Crankset on it but I am moving it to another bike and replacing it.
    'brifter' is a lame word.
    Quote Originally Posted by jtmoney528 View Post
    If you have a GXP bb you need a GXP crank.
    I work for some bike racers
    and a bunch of skateboards
    Dec 2014
    Here is a picture to confirm
    Dec 2014
    I am gettin a new Trek Domane, am I right in assuming that I canít take my current crankset and move it over to it?
    You
    Need
    A
    GXP
    Crank
    That will work for the Trek as well.
    Dec 2014
    You
    Need
    A
    GXP
    Crank
    That was my main concern, thanks man, greatly appreciate it.
    No prob. The Trek BB90 basically uses just the bearings from whatever system you're using that would have previously been inside threaded cups. They're all 37mm OD, Shimano are 24mm ID, SRAM are 24/22, Campy are 24. The bearings press directly into the frame.
    Apr 2012
    I guess GXP cranks can be considered "Universal" in that with adapters / spacers can be fit to any road BB standard (aside from square taper of course)?
    Whereas SRAM BB30 you have some that are "short spindle" others are "long spindle" which fit more 30mm BB standards, and maybe "some" 24mm BB if bearings can be sourced (eg BB86).
    scott s.
  1. 2015 SRAM Red different than 2010 SRAM Red?
    By sramred in forum Components, Wrenching
    Last Post: 05-16-2015, 03:33 AM
  2. Can I use a new red 11 sp crankset with older v1 10 sp Red parts?
    By The Squeaky Wheel in forum Components, Wrenching
    Last Post: 08-03-2014, 05:17 PM
  3. Replies: 5
    Last Post: 04-21-2013, 06:15 AM
  4. 2011 Red vs 2012 Red and 2011 Red with WiFLi shift quality
    By jmess in forum Components, Wrenching
    Last Post: 03-03-2013, 06:39 PM
  5. SRAM Force Crankset VS. Ultegra SL Crankset
    By floridacyclist in forum Components, Wrenching
    Last Post: 10-13-2008, 06:48 PM
