Results 1 to 6 of 6
    TLN
    TLN is offline
    Jan 2017
    Sram Red Hydro cable routing (Spesh Aerofly).
    Hi all.
    I got a nice Allez Sprint that came with Spesh aerobar from factory and Sram Force 1x. Recently I got a Tarmac Disc with Red Hydro and great choice of high-end components. Before I put my Allez on sale I decided to move aerofly to Tarmac and now I have issues:
    With mechanical Force I have two options to route my cables:
    On my Spesh aerofly I have two cable holes and it works perfectly fine(using option pictured on the right).
    But on hydro version I have only option to route the cables (as pictured on left). I haven't tried yet, but hole will be too small to put two cables inside. I've found some messages from the users on forums, mainly because cable takes sharp turn, but no one was using an aerofly handlebar.
    Obviously, routing cable outside of handlebar is not an option.
    Any ideas what should I do?
    Forever a Student
    Mar 2014
    You can probably get both into the inside hole. I have those bars and I have both 5mm brake housing and 4mm shift housing through the inside holes.
    It is possible, well provided your holes are clean and open and don't have extra fiber or resin in the way.
    It's very difficult to do, they don't just fit, it takes some experience and the right technique. There's probably someone at the LBS who's good at it, this is not a new problem. Not for these particular bars or others just like them.
    use a torque wrench
    TLN
    TLN is offline
    Jan 2017
    Yeah, I've put a random cable while pulling one of shiftes and was able to do so. But it still looks too tight to me. Although, I understand that it will look superclean if I manage to put it together.
    Forever a Student
    Mar 2014
    It's too tight for sure. Clearly not designed for two hoses/housings. Really should be though.
    use a torque wrench
    Reputation: Wetworks's Avatar
    Aug 2012
    I went in the other direction and just added this bar to my new Sprint. I have a mechanical 105 setup, so it's different from yours, but I had a similar problem. What I chose to do was to 'S' turn the brake cable to the outside routing hole. No issues with brake performance from what I can tell. Not sure if this is at all helpful, but felt I should at least throw it out there.
    TLN
    TLN is offline
    Jan 2017
    I probably need to post side-by-side pic. I haven't moved shifters yet (too lazy to disassemble current one) but it will be pretty tight S.
    Also, I've notices that Venge Red Disc comes with a bit different aerofly: there's a bigger hole to accommodate two cables, but there're holes where it attaches to the stem to route cable through the frame. Not sure if I want to have that bar on "normal" bike.
    I'm thinking of replacing aerofly with aeronova, but that's just throwing money on a problem. Should probably give Sram and Shimano a call.
  1. Replies: 1
    Last Post: 07-05-2016, 08:08 AM
  2. Replies: 2
    Last Post: 05-05-2015, 06:39 AM
  3. S-Works Aerofly Carbon Handlebar?
    By AlphaDogCycling in forum Components, Wrenching
    Last Post: 04-22-2015, 07:06 AM
  4. Clip-on time trial bars on SWorks Aerofly bar?
    By knukkeltje in forum Specialized
    Last Post: 06-16-2014, 09:57 AM
  5. Just got my hands on SRAM Red 22 Hydro Setup
    By Lawfarm in forum Components, Wrenching
    Last Post: 08-22-2013, 08:02 AM
