Results 1 to 11 of 11
    Roadbike Rider
    Reputation: Chainstay's Avatar
    Mar 2004
    Stem options for 1 inch steerer
    Almost all the stems available are made to fit 1 1/8 inch steerer tubes. I have two bikes with 1 inch threadless steerer tubes. One currently uses a Ritchey Pro 1 1/8 stem with an insert. The other has an older 1 inch Deda stem
    I want to buy a shorter stem for each bike but cannot find either inserts or 1 inch stems. Can anybody recommend my best options.
    "It's supposed to be automatic, but actually you have to push this button. "
    John Brunner (Stand on Zanzibar)
    Not a rocket surgeon.
    Nov 2008
    Thomson and VO makes a shim. I cant really recommend any good 1" stems.
    Stem Shim 1" to 1 1/8" - Threadless Stems - Stems - Components
    Jan 2013
    Re: Stem options for 1 inch steerer
    I second that. Get a shim. I think I saw one on Wiggle.
    Reputation: headloss's Avatar
    Mar 2013
    shim... and also a 1-1/8" top cap (unless you use a spacer above the stem). Watch the stack-height of the stem vs the height of the shim too; Thomson makes more than one size. Ideally, you want a shim that is a mm or two below the stack height of the stem or the top-cap may not fit snugly.
    Jan 2013
    Reputation: PlatyPius's Avatar
    Feb 2009
    Any good shop should have shims. There are no 1" stems available anymore.
    Other countries need to stop hatin' or we'll unfriend them. - Christine
    Apparently I left my reading comprehension glasses in my ass. - DrRoebuck
    Still, it felt great and I felt like I was sitting on some kind of vibrator -Touch0Gray
    Roadbike Rider
    Mar 2004
    Thank you guys
    Reputation: logbiter's Avatar
    Sep 2005
    Some stems come with shims too, the last Ritchey I got came with a shim. Your LBS will have them though.
    Crash Test Dummy
    Aug 2012
    Nashbar has some, FSA brand.
    Banned forever.....or not
    Aug 2002
    10 years ago, just about every 1-1/8 stem came with a 1" shim. Back then it was still possible to get a 1" stem. They were beginning to become rare. (they looked "skinny" compared to 1-1/8 stems)
    Dogbert.
    I>U
    Reputation: QuattroCreep's Avatar
    Nov 2009
    The problem with finding a 1" stem is that is most likely going to be NOS and be sized for 26mm bars not 31.8mm bars, unless that is what you want. Then Ebay is your friend.
    Shims
  1. Replies: 5
    Last Post: 06-09-2012, 05:57 PM
  2. 1 inch steerer carbon fork
    By wayne in forum Components, Wrenching
    Last Post: 10-22-2011, 03:42 AM
  3. 1-1/8 stem on 1 inch steerer
    By DeLuz in forum Components, Wrenching
    Last Post: 09-23-2009, 06:41 PM
  4. Klein Aeros carbon fork w/1 inch steerer?
    By grodo in forum Bikes, Frames and Forks
    Last Post: 09-14-2007, 01:59 PM
  5. 1 inch carbon fork/steerer question
    By merckxman in forum Save Some Weight
    Last Post: 09-06-2006, 10:36 AM
Sea Otter Classic
Contest
