I usually install it so that the writings on the hub are not upside down when seated on the bike, but does it matters at all? I'm thinking it does not since everything seems symmetrical and my tires don't have directional thread patterns. Can the cones adjustment or locknuts be affected in any way?
Yeah I always put it there. Just realised that the rest of the wheel has been rotated for a little while, didn't seem to have any effect but I wanted to make sure.
No it does not matter. The bearings work the same in both directions.
Being symmetrical would be the only issue. If the rim is slightly off center then flipping the wheel would make your brake pads not even.
I was wondering what the hell her wheel had to do with her swimsuit... Then I got it!
I had never put the wheel backwards when I had a magnet. But now I use Garmin speed sensor and attach it to the back wheel, so it's not a good reminder anymore.
Back in the day when everyone rode box rims, the rims would often have a sticker on them, so that when you built a front wheel, the hub label and the rim label had to go in the same direction The QR always went on the left.
Another question regarding my Shimano front wheel.
I left just a little play when adjusting the hub preload (backed off 1/32 turn when cones made contact with bearings) When mounted on the bike with almost no QR pressure, I can feel the play by moving the rim side to side, which gives a slight knocking sensation. When I fully close the QR, I can't feel the knocking anymore. But if I seat on the bike and do the same test, there's a very small knock that can be felt when the rim is in certain positions. I guess that means I still have too much play, even if the "classic" test is conclusive?
if there's no play with the skewer tightened normally (not overtightened) while i'm off the bike, i'd call it good. i like a little play when wheel is mounted and skewer is loose (before tightening).
Related Threads
Road Bike, Cycling Forums
5.4M posts
205K members
Since 1990
