Results 1 to 3 of 3
    Apr 2018
    tiagra 4700 sifter compatibility
    Alright so there was a thread on this forum that while it did provide the information didn't really give me a conclusive answer I apologize if this is the incorrect way to go about this but, From the thread, I concluded a tiagra 4700 road shifter could be used with a 5800/6800 rear derailleur for a rear 10 speed bike using a 10 speed cassette. I assume thats what was supposed to be gained from the thread. Which brings me to my new question are 5800/6800 rear derailleurs interchangeable with r8000 shifters? If so could i pair my 4703 shifters with an RD-R8000-GS rear derailleur in a 3x10 configuration to gain a clutch rear derailleur?
    link to previous thread on the 4700 to 5800/6800 rear derailleur topic:
    Tiagra 4700 shifter pull ratio
    Reputation: Lombard's Avatar
    May 2014
    The shift ratios should be compatible. As long as they are, the derailleur doesn't care whether the shifter is 10 or 11 speed.
    From my knowledge, Shimano changes their road shifter ratios from:
    4600/5700/6700/7900
    to
    4700/5800/6800/9000.
    After that, ratios stayed the same. So 5800/6800 should be compatible with R8000.
    Oct 2013
    4600/5700/6700/7900
    to
    To be less confusing, I would say it this way -
    Shimano changed their road rear derailleur ratios from:
    4600/5700/6700/7900
    to
    After that, rear derailleur ratios stayed the same. So the 4700/5800/6800 rear derailleur should be compatible with the R8000.
    The 10 speed 4700 shifter is not compatible/replaceable with the 11 speed 5800/6800/R8000 shifter unless other components are also replaced (chain, rear cassette, etc)
  1. Tiagra 4700 shifter pull ratio
    By Z'mer in forum Components, Wrenching
    Last Post: 03-15-2018, 06:51 AM
  2. Front der arm rubbing tire (CX/Tiagra 4700)
    By zephxiii in forum Components, Wrenching
    Last Post: 10-01-2017, 06:48 AM
  3. Question about Tiagra flat bar brake levers (BL-4700)
    By kapusta in forum Components, Wrenching
    Last Post: 03-10-2017, 03:31 AM
  4. From SRAM Rival (2010) to Tiagra 4700 or 105 5700?
    By musicmaster in forum Components, Wrenching
    Last Post: 07-22-2016, 07:16 AM
  5. BB housing compatible with Tiagra 4700 BB ?
    By Purebred in forum Components, Wrenching
    Last Post: 05-21-2016, 06:34 AM
