Results 1 to 22 of 22
    Frog Whisperer
    May 2003
    Tick, Tick, Tick
    I have been riding Campy for decades now and 2 of the three bikes are absolutely perfect. (square taper on the other 2) BUT my Waterford has developed at tick coming from the bottom bracket as the right side comes over the top (about 11:30) and the left is 180 degrees (obviously) It ONLY occurs when I am up on the pedals with my maximum force on the pedals. It does not always do it either. A lot of digging turned up this article regarding Ultra Torque and the hirth joint they used. (10 speed)
    Campagnolo Ultra Torque Problem? - RogueMechanic
    As this sound was not always evident, is it possible that the bearings are a bit worn and new bearings would stop the ticking?
    Of course I'm sure...that doesn't mean I'm right.....
    "There's no sense being stupid unless you show it."
    "that was like trying to teach a goldfish how to play basketball over the phone."
    a real member's member
    Jul 2016
    no harm in overhauling the bb, right?
    Frog Whisperer
    May 2003
    Quote Originally Posted by blackfrancois View Post
    No harm indeed, BUT if it doesn't solve the problem, seems like a waste pf time and money. Like that article says to check, I squeezed the left crank arm and down tube and I can hear and feel the popping from the wavy washer deflecting.
    Frog Whisperer
    May 2003
    although I did just order a new wavy-washer, maybe the old one is weak (worn out?) I do have 18,000 miles on it.
    Dec 2005
    Sounds like your crank arm hitting the FD wire/end cap thingy.
    Mar 2004
    Quote Originally Posted by woodys737 View Post
    That's what I was going to say.
    Reputation: velodog's Avatar
    Sep 2007
    Too old to ride plastic
    Frog Whisperer
    May 2003
    Quote Originally Posted by mackgoo View Post
    Nope, that isn't it, if it was, the crank arm would have to be deflecting a good 1/2 inch and quite frankly, I am just not that strong!
    Feb 2002
    Quote Originally Posted by Touch0Gray View Post
    Be very careful putting too much into what Rogue Mechanic has to say. He spent some time on this site and let's just say his claims were cut to ribbons by people who knew better.
    Clicks can be hard to diagnose. Clicks tied to your pedaling can come from
    - BB (grease all threads in contact with the frame and BB, all metal to metal contact surfaces, and torque to the recommended settings, which can be quite high), the faces of tapered BB axles if they have a little corrosion
    - bolt holding the BB cable guide onto the frame (grease threads and make sure the bolt is not touching the BB shell inside the frame)
    - crank bolts (grease threads and washers)
    - chain ring bolts (take them all out and grease the threads, the faces where they contact the CRs, and the CRs where they contact the crank spider arms)
    - a dirty chain, inadequately lubed chain, stiff link in a chain or a burr on one of the "break off" special links used to assemble the chain
    - front derailleur clamp (clean and put a light film of grease on the inside of the clamp where it touches the seat tube)
    - front derailleur cage hitting crank arm
    - the pedals (grease the threads and the shoulders of the axle where it butts against the crank arm, get some wax, silicone etc. on the cleats, check for play in the bearings, squirt some lube into the guts of the pedal machinery if possible)
    - shoes/cleats - loose cleat nut rattling around in the shoe sole, shoe/cleat interface, cleat bolts, cleats touching pedals (wax lube, silicone, or furniture polish)
    - seat post and saddle (grease the post, seat post clamp, seat post bolts, saddle rails, and add some oil to where the rails go into the saddle body)
    - bars and stem (grease the stem where it clamps to steerer or goes into the steerer if quill type, top cap, stem bolts at both ends, h'bar bolt if quill stem, and h'bar where it goes through the stem)
    - grease/tighten QRs and where the hub axle contacts the frame
    - tighten cassette lock ring, grease cassette hub body and cassette spacers
    - grease steerer tube spacers (if threadless)
    - replaceable derailleur hangers (remove, clean, grease all parts and threads, reassemble)
    - any other bolt (bottle cages, derailleur clamps, derailleur bolts, shift cable casing stops, etc.)
    - cables hitting the frame (cable donuts), or shifting in their end ferrules (lube contact points).
    This is a good list, and it reminds me why I hate diagnosing ticks and clicks so much!
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    You wouldn't happen to be riding with old-school lace-up cycling shoes, would you? Hint--check your laces.
    Frog Whisperer
    May 2003
    BOA.... so nope...LOL
    'brifter' is a lame word.
    Rogue Mechanic? That guy is an idiot. He probably still swears up and down that the UT system has a basic design flaw, but he's the only guy that has that problem. The problem could be worn bearings, they can click when worn. I doubt the wave washer is worn out, it's a simple spring that just sits there, the only time springs wear/fatigue is when they're compressed or released, not when static.
    I work for some bike racers
    and a bunch of skateboards
    Frog Whisperer
    May 2003
    Yeah I am going to throw bearings on it, maybe cups too, but I have some big irons on the fire right now, and will be of the bike for 2 weeks, which wil be a good time to do it.
    Frog Whisperer
    May 2003
    update: I had ordered the bearings but never had the time to install them then had cataract surgery on my eyeballs. Finally got around to getting them in this morning, The bike is like new again, so it WAS the bearings, new cups not required!
    What the what???
    Jul 2009
    Maximum effort and all you can muster is a "tick"??? I'd be embarrassed to even report such a problem.
    Glad the bearings solved the problem, T0G.
    The Law of Headwinds states: If the ride out is easy... wait.
    Sep 2007
    I hope you got out and put some miles on those new bearings.
    Frog Whisperer
    May 2003
    Another 37 or so today, like 181 this week, 270 in the last 7 days and 365 this month. (14th)
    Sep 2007
    YaHoo!!
    Nov 2014
    So, more importantly, how is your eyesight?
    Frog Whisperer
    May 2003
    Quote Originally Posted by GKSki View Post
    Another appointment next Wednesday, a follow up. I will have numbers then but it is better than 20 /20, I am certain. If I am in good bright light, I don't even need readers!
    Frog Whisperer
    May 2003
    Quote Originally Posted by Opus51569 View Post
    Very little embarrasses me brother
  1. the Greek drama ... tick,tick,tick,tick
    By myhui in forum Politics Only
    Last Post: 09-21-2015, 08:12 PM
  2. Tick..Tick..Tick..Tick..Tick.. sound from the Crank!!!
    By talentous in forum Components, Wrenching
    Last Post: 06-30-2015, 06:41 PM
  3. Help m diagnose a "tick....tick....tick..."
    By RedRex in forum Components, Wrenching
    Last Post: 04-13-2009, 07:47 PM
  4. And the tick tick tick is gnawing at my sanity.
    By JoeDaddio in forum The Lounge
    Last Post: 04-30-2008, 11:58 AM
  5. Bottom bracket ... tick-tick-tick...
    By Macho Man Savage in forum Components, Wrenching
    Last Post: 05-30-2006, 01:33 PM
