Results 1 to 23 of 23
Thread: Toe in
    Jan 2018
    Toe in
    Any quick rule of thumb for when it comes to dialing in toe in? Currently setting up some new Dura-Ace brakes with Exalith pads. I know they are going to go 'WHIRRRR'.
    Reputation: OldZaskar's Avatar
    Jul 2009
    For years, I've set front and back pads slightly toed in - using a credit card to set the gap. A friend of mine - and more importantly, a pro mechanic - told me he's been setting up carbon rims and carbon-specific pads with no toe - just flat to the rim. I set mine up like that (Swiss Stop) and they're working well - great breaking, no chatter.
    Would also like to hear others' recommendations/findings
    I always used a credit card too. Setting them up once when I didn't have a cc handy so went flat taught me I was wasting my time.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Toe in not required. I've never toe'd in road pads. And I run the Exalith pads. They're great.
    Jan 2018
    Cool, thanks everyone! All very good suggestions. I'll probably just keep them mostly flat since that appears to be the consensus.
    'brifter' is a lame word.
    I can't remember the last time I set up brake pads any way other than dead flat. I adjust thousands of brakes every year and they're all flat. If they make noise it's pretty much always contamination of some type.
    I work for some bike racers
    and a bunch of skateboards
    Apr 2006
    This.....and you will never go back!
    https://www.amazon.com/Tacx-Brake-Sh.../dp/B001D8WLQO
    Sent from my SM-G950W using Tapatalk
    Feb 2002
    Quote Originally Posted by adilosnave View Post
    Back in the day when brakes were a lot more flexible than they are today and pad compounds were not nearly as good, toe-in was standard practice and you sometimes got serious squeal if you didn't. These days, it's generally not an issue and certainly not a requirement for most setups.
    Reputation: Lombard's Avatar
    May 2014
    Awhile back, I had a bike with a nasty brake pulsation problem. It was a Cannondale hybrid with V-brakes and a Headshok. Tried toeing in, that didn't work. Tried toeing out, that worked for awhile, then the pulsation came back. Changed pads, sanded down brake tracks as much as I could, but there was a wear groove that I couldn't get below. Problem still existed.
    New rims, problem gone!
    I have never had a squealing problem on either of my road bikes and both are adjusted flat. I will say that when I have toed brakes, there was definitely reduced braking power.
    Apr 2006
    Shimano still recommends a toe in of 0.5 mm. See page 21.
    http://<br /> https://www.google.com...rrkPC-XhTBWRYs
    Jan 2018
    Leave it to Tacx. That is so clever!!
    If thousands and thousands of people are setting up their pads flat, which they are, and not having problems it's not needed. It will cause pads to wear faster.
    Quote Originally Posted by goodboyr View Post
    I did not realize there were multiple tools on the market for this. I have always just stuck a think piece of cardboard between one end of the pad and rim.
    Apr 2006
    OTOH, you have always argued that if it's in the Shimano specs there must be a reason......just sayin'
    Nov 2002
    I guess you're not buying that when you brake, the brake arms twist (flex in the brake arms plus play in the pivots) so that the center of pressure is towards the rear of the pad, which means the pad will wear more at the back of the pad. To get uniform wear on the pad, you should toe them in. Maybe road brakes are so stiff that this is a non problem. However, with V's and cantis, which all seem to have play in the pivots in my experience, toe in is necessary.
    Not w/ modern road brakes.
    Brake pad adjustment is somewhat more generic and less critical than choosing the correct derailleur or using the proper rotor/pads.
    Apr 2006
    Of.course. Just doing a little trolling.....that's all.
    From you I take no offense
    Oct 2005
    Wow I’m shocked. No one uses a dime?
    I keep a dime in my toolbox just to set toe in and my brakes always work great.
    PS - two nickels will NOT work.
    Not a rocket surgeon.
    Reputation: tihsepa's Avatar
    Nov 2008
    Flat has worked fine for me. For many, many years.
    Reputation: Braavos's Avatar
    Oct 2015
    You will find it is flatted after brakes a while and adjust it again if toe in is necessary in your theory. Always flat shoe touch for me.
    Nov 2002
    Why does toe in stop a brake from squealing?
  1. Turf Toe (or big toe joint pain) from biking?
    By jtuds in forum General Cycling Discussion
    Last Post: 08-08-2016, 10:21 AM
  2. Toe in or toe out with cleats?
    By novetan in forum General Cycling Discussion
    Last Post: 02-08-2013, 03:12 AM
  3. Random toe numbess (TOE PICS lNCLUDED...F YEA!)
    By Sylint in forum The Lounge
    Last Post: 04-26-2012, 02:39 PM
  4. Replies: 0
    Last Post: 11-19-2009, 09:07 AM
  5. Toe-in Toe-out Aghh
    By argylesocks in forum Cyclocross
    Last Post: 10-10-2005, 10:09 PM
