Results 1 to 9 of 9
    Reputation: supraholic's Avatar
    Oct 2010
    TR Lightweight brake set? Anyone tried them?
    I'm about to pull the trigger on some TR Lightweight Brake Caliper sets but I wanted to see if anyone here have tried them before?
    Here is a link for the description.
    TR ROAD BIKE BRAKE CLIPER SET SWISS STOP COMP Dura Ace | eBay
    I am currently on a Ultegra set-up.
    Militant commuter
    Reputation: SilverStar's Avatar
    Jan 2008
    Do a search for "Feather" and "Planet X" brakes...they all share the same design, and may simply be rebranded versions all made by the same factory. A friend of mine has the Planet X models on his tri bike and really likes them.
    "Luminous beings are we...not this crude matter!"
    Oct 2010
    Quote Originally Posted by SilverStar View Post
    Do you know if it is dual pivot?
    Not a rocket surgeon.
    Reputation: tihsepa's Avatar
    Nov 2008
    Why would you buy single pivot brakes?
    Oct 2010
    Quote Originally Posted by tihsepa View Post
    That's the reason why I'm asking because I'd rather not buy one if it will degrade my stopping power. Yes, I'm sure no one here will down grade to single pivot.
    Nov 2008
    I would bet they are loghter but definately wont stop as well.
    Militant commuter
    Jan 2008
    They are single pivot brakes...and there's nothing inherently wrong with singles. Campagnolo still puts single pivots as a rear option on their brakesets. Modulation isn't as good as a modern dual-pivot, but they aren't "weaker" or anything else that I've experienced, provided decent pads are installed.
    Banned forever.....or not
    Aug 2002
    Stick with a "real" brake caliper if you want to be able to stop quickly.
    Read this..
    http://eecycleworks.com/VNJune%20BrakeTest.pdf
    Dogbert.
    I>U
    Reputation: Kontact's Avatar
    Apr 2011
    Quote Originally Posted by MR_GRUMPY View Post
    Read this..
    Well, did you read it? It's actually a pretty complimentary review since they chock up the lack of power to the stock brake pads. Put some Swisstops in and they'll work very well. Some versions now come with Swisstops.
    These aren't "single pivots" in the sense you guys are talking about. Like Zero Gravity's and others, this design has a second pivot - in the cam arm. And that cam arm increases the braking force in a similar way to a double pivot brake. Comparing the Feather brake or Zero Gravity to a classic '70s or '80s single pivot is a little absurd.
    A sub 200 gram brakeset that comes in colors and costs $110? I would certainly consider it, even if I had to replace the pads. Planet X UK also has a 230 gram forged version in silver and black for $82. I think this is probably the smartest buy in an ultralight brakeset.
  1. Replies: 18
    Last Post: 01-04-2010, 12:07 AM
  2. Lightweight RD, anyone seen this?
    By de.abeja in forum Components, Wrenching
    Last Post: 01-07-2008, 07:49 AM
  3. New contender in the Lightweight brake arena.
    By Juanmoretime in forum Save Some Weight
    Last Post: 03-30-2006, 03:48 PM
  4. What is lightweight?
    By trairden in forum Save Some Weight
    Last Post: 06-06-2005, 03:38 PM
  5. Need new seatpost...lightweight!!!
    By AlanS in forum General Cycling Discussion
    Last Post: 09-15-2004, 03:41 PM
