Results 1 to 6 of 6
    Jan 2013
    Training skewers for disc brake wheels
    Could someone recommend training skewers for my roubaix that has disc brakes. These skewers are different than the friction lock skewers that I have had for 50 years, they screw into threads on one of the forks. However, the ends will not go into the part of the trainer that holds up bike. Can't find the correct term on amazon to search for this.
    Thanks.
    Sent from my Lenovo TB-X304F using Tapatalk
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    Rollers.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Oct 2011
    Robert axle project makes them.
    I machined my own but understand most will not be able to do that.
    Jan 2013
    Thanks tlg. $50. Wow. I can see why you machined your
    Own. But a milling machine is going to set me back a bit....
    Old and in the way.
    Aug 2014
    You'll need special axles, but make sure the axles will work with you trainer! I learned the hard way that some won't work together. What brand/model trainer?
  1. Disc brake fork on a rim brake frame
    By wradom in forum Bikes, Frames and Forks
    Last Post: 04-05-2018, 12:56 PM
  2. Disc Front Brake / Rim Caliper Rear Brake Experiment
    By mrwirey in forum General Cycling Discussion
    Last Post: 02-20-2016, 04:08 AM
  3. disc brake to caliper brake conversion?
    By cyclisme! in forum Components, Wrenching
    Last Post: 09-24-2015, 10:01 AM
  4. Disc Wheels for 2012 Specialized CruX Apex Disc
    By Merc in forum Wheels and Tires
    Last Post: 01-22-2012, 11:57 AM
  5. Replies: 8
    Last Post: 07-28-2010, 10:45 AM
