Results 1 to 7 of 7
    Jun 2013
    trek 5.9 madone ultegra!!!
    got cracking noise from crank area!!so local bike shop changed my pedals and put new bottom bearing cups on the rod,,not changed rod tho..checked frame nuts bolts screws etcccc..but still makes a cracking noise every now and again..mostly after free wheeling or putting pressure on down stroke.(only about 20 times over 50 miles)my shop have no idea now!!!!so just hoping theres some advice out there about my problem thanks mark...trek 5.9 madone 2004 ultegra
    Reputation: PlatyPius's Avatar
    Feb 2009
    I have no idea what a rod is, but your exclamation mark button appears to be stuck, and you seem to have a bold, large-type problem as well. They may be related.
    Other countries need to stop hatin' or we'll unfriend them. - Christine
    Apparently I left my reading comprehension glasses in my ass. - DrRoebuck
    Still, it felt great and I felt like I was sitting on some kind of vibrator -Touch0Gray
    Not a rocket surgeon.
    Reputation: tihsepa's Avatar
    Nov 2008
    Why are you YELLING?
    Mar 2013
    I had an issue where if I coasted and then applied a decent amount of power right away I'd get a loud pop that I could feel through the frame and sounded like the crank area. It ended up being the rear hub. It wasn't on a Madone though, it was a Superfly (Trek carbon hardtail 29er with bontrager wheels)
    wim
    wim is offline
    Feb 2005
    A number of FH-6600 Ultegra hubs with sticky pawls got out into the market some years ago. The usual symptom was one loud pop when applying power after low-speed freewheeling. Most people ignored the problem because it occurred infrequently and at very low speeds only. From what you're saying or trying to say, it could well be that—especially if you've got the FH-6600. If it is, no big deal. I'd ignore it.
    Jun 2013
    Try tightening the seat post clamp I had a similar problem when applying down force.
    Jun 2013
    i ment spindle.
    Quote Originally Posted by PlatyPius View Post
  1. 2011 Trek Madone 4.7 vs 2012 Trek Madone 4.6
    By mitchopkins in forum Bikes, Frames and Forks
    Last Post: 04-26-2012, 01:41 PM
  2. Bianchi Infinito Ultegra vs. Trek Madone 5.2
    By Joshuamcc in forum Bianchi
    Last Post: 11-15-2011, 05:12 PM
  3. 2011 Cannondale Super six ultegra vs. 2011 Trek Madone 5.2
    By kevo123 in forum Bikes, Frames and Forks
    Last Post: 01-31-2011, 09:06 AM
  4. 5.2 Trek Madone 2007 vs 4.5 Trek Madone 2009
    By newyorker1212 in forum General Cycling Discussion
    Last Post: 08-01-2009, 08:00 AM
  5. Replies: 1
    Last Post: 11-07-2005, 06:05 AM
