Results 1 to 9 of 9
    Jul 2008
    Triple to Compact Double crankset questions
    I am converting my 2006 Specialized Roubaix from a Campagnolo Mirage triple crankset with a Phil Wood BB to a compact double crankset. I believe the BB size for my bike is 68mm. So my question is could I switch to a Campagnolo Centaur CT Power-Torque Crankset (50/34). I know I have to change my BB and was wondering what kind of BB I would need for my desired double crankset swap?
    Dec 2009
    You'll just need the newer, external Campagnolo bb cups. Fortunately they are cheaper than the square taper variety because they are just cups - the bearings are pressed on the crank spindle. Also make sure you get the english threading rather than italian.
    Jul 2008
    Ok great thank you. And this external BB would fit on a aluminum frame from 2006?
    Dec 2009
    Yeah, the cups will fit any frame with a threaded bb. http://www.campagnolo.com/jsp/en/gro...at_catid_2.jsp
    Jul 2008
    ok awesome... one last question I have a 9sp RD that dosn't matter for the crankset right? might just need to get longer chain and cables?
    Dec 2009
    That should be fine.
    Jul 2008
    ok awesome... thanks for all the help
    Jul 2007
    Quote Originally Posted by astanafan708 View Post
    I'd get the frame chased and faced too before fitting the newer type BB. It ensures the faces of the BB shell are parallel and gives the bearings the best chance of a longer life. A good LBS wont charge much for this but its essential to have the right tools.
    Jul 2011
    Quote Originally Posted by baker921 View Post
    He it right, definitely get it checked.
  1. Double Vs Triple Crankset
    By Rockass in forum General Cycling Discussion
    Last Post: 05-06-2011, 07:30 PM
  2. Double or Triple crankset??
    By rusty4x in forum Beginner's Corner
    Last Post: 11-22-2009, 06:28 PM
  3. Triple to Double Crankset what I need to know
    By nismosr in forum Components, Wrenching
    Last Post: 10-17-2007, 02:47 PM
  4. Crankset dilemma: Triple vs. Compact double
    By buff91 in forum Bikes, Frames and Forks
    Last Post: 06-15-2005, 06:33 PM
  5. Replies: 3
    Last Post: 03-11-2004, 05:27 PM
