Results 1 to 2 of 2
    Jul 2010
    Truvativ ISIS to Hollowtech?
    A friend has a 2004 Cannondale r600 caad5 with a Truvativ ISIS BB and double crankset for a 2x9 speed drivetrain. He would like to change to a compact double and I happen to have a spare Shimano Hollowtech compact crankset for 2x10. Are there any issues with making this switch? Also, he is about 6'2" and it is a 58 cm frame with 175mm crank arms. My cranks are 172.5. 2.5mm just seems like too little to worry about.
    Aug 2007
    Quote Originally Posted by econprof View Post
    This switch will require a new Shimano bottom bracket to go with the crankset. I wouldn't worry about the crank arm length.
    I'm not sure about the 9 speed chain on the 10 speed rings, but if there was a problem, I think it would only be that the 10 speed rings may wear faster, because they are thinner. I'm not certain if the distance between the rings themselves is changed from 9 to 10 speed. If so, that may affect shifting on the front.
  1. Hollowtech II crankset ...
    By Optimus in forum General Cycling Discussion
    Last Post: 08-02-2010, 03:09 PM
  2. ISIS or External BB - Accidentally Purchasesd ISIS Crank
    By cdrymalla in forum General Cycling Discussion
    Last Post: 05-16-2009, 11:33 AM
  3. Hollowtech II? Bad?
    By heidio in forum Components, Wrenching
    Last Post: 04-09-2009, 03:45 PM
  4. centaur UT crankset or Truvativ Elita ISIS
    By fah35 in forum Components, Wrenching
    Last Post: 04-22-2007, 02:41 PM
  5. FSA SLK ISIS or Shimano Ultegra Hollowtech II
    By sound in forum Components, Wrenching
    Last Post: 02-15-2006, 06:58 AM
