Results 1 to 4 of 4
    Dec 2002
    ultegra 10 speed levers mounting
    any detailed descriptions of how to tighten and loosen mounting clamp on 10 speed shifters
    Feb 2002
    Quote Originally Posted by nelsbruce View Post
    Mentally picture the clamp that goes around the handlebar as having a bolt sticking out of it down the center of the shifter body. Then peel back the lever hood (from the front of the bike toward the handlebars) and you will see a cavity in the lever body. Stick a 5 mm allen wrench into that hole and wiggle it around until it drops into the allen nut. The allen wrench will be pointed toward the handlebar. The nut is right hand thread and you just keep turning it until the lever comes loose.
    If you Google "Shimano Tech Docs" you will find some blow-up images of all the parts of the shifter and clamp to get a better understanding of how things go together. You also can Google the topic along with the word "video" and you will find plenty of tutorials.
    May 2009
    6600 has the bolt head on the outside of the shifter body(under the hood). Slide wrench in tilted slightly down along center line and slide back towards bar to get engaged. 6700 is on top of body right in the center, just pull hood back & look(as KI said).
    Dec 2002
    thank you for help
  1. Best place to snag 9 speed ultegra levers?
    By bward1028 in forum Hot Deals
    Last Post: 12-28-2007, 11:03 PM
  2. Mounting Ultegra shift/brake levers on 'bullhorn bars"?
    By theimperviousone in forum Components, Wrenching
    Last Post: 08-06-2007, 10:11 AM
  3. Replies: 6
    Last Post: 10-30-2005, 06:08 AM
  4. Replies: 5
    Last Post: 12-19-2004, 05:58 PM
  5. Compatibility Q: Ultegra 9-Speed, STI levers and Deore Rear Derrailleur?
    By mdehner in forum General Cycling Discussion
    Last Post: 05-12-2004, 03:35 PM
