Results 1 to 21 of 21
    Jun 2005
    Ultegra 11 Chain came w Quick Link
    I just ordered 2 HG701 chains from Western Bike Works, and they came with quick links instead of pins. I can't get the thing on by hand. Do I need the Shimano tool, or can I use the Park Master link tool?
    Reputation: askmass's Avatar
    Sep 2009
    Quote Originally Posted by TiCoyote View Post
    I'd heard Shimano had gone the link route.
    I use KMC missing links on Campy chains instead of the supplied pins and this dual tool- https://www.amazon.com/Elat-Park-Bic...SHYYTFIVPWUY6Q
    Can't imagine you'd need anything besides the Park tool if it's the new version that both opens and closes (before, Park sold two separate open/close sets).
    “When the spirits are low, when the day appears dark, when work becomes monotonous, when hope hardly seems worth having, just mount a bicycle and go out for a spin down the road, without thought on anything but the ride you are taking.” ― Arthur Conan Doyle
    Jun 2005
    The thing is, it looks like you need some spreading force to lock the link, and the shimano tool lets you spread by squeezing the handles. I'd buy the shimano tool, but it's twice as expensive, and nobody stocks it.
    Is the quick link a permanent change, or did I get old stock chains?
    -Lock the rear wheel and use the cranks to snap it in place.
    -You didn't get an old chain.
    Jan 2010
    with the chain open at the bottom and gearing in the small-small combo, mark where you are going to remove links to get to the correct length.
    remove unwanted links.
    take chain off small ring temporarily while attaching link by hand.
    put chain back onto small ring and check RD for correct clearance.
    repeat last 2 steps if necessary to get correct chain length.
    with link hand tight, rotate chain to top, lock rear wheel and push on crank. observe link clicking into engagement. check it's nice and free.
    There's sometimes a buggy.
    One.
    Quote Originally Posted by bikerjulio View Post
    Or just make it the same length of the one you took off if that was known to be correct.
    Jan 2010
    The existing chain may or may not be the "correct" length, since there can be disagreements on this topic. My method starts from basics, so that a previous mistake is not repeated.
    One.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    No tool needed.
    Jun 2005
    This was really helpful! Thank you so much!
    May 2012
    I got one of the new Shimano quick links and holy crap was it hard to close! Ive use KMC and Sram and nothing like the Shimano. I normally hold the brake and turn pedal with my hand on bike stand to close them. Could not do it with this one. I had to put bike on the floor and stand on pedal to get it to close. I havent tried to take it off yet.
    Jun 2005
    I shifted the chain in the small-big combo. I held the wheel with my left hand, and put pressure on the crank with my right. It did take some serious pressure though. It probably would have been easier had I used my foot.
    Russian Troll Farmer
    Sep 2016
    I believe Shimano gave up on the replacement pins back on 9-speed.
    "L'enfer, c'est les autres"
    tlg
    tlg is online now
    May 2011
    Why would you believe that? They've been using pins on 10 and 11 speed chains.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Shoot, an HG701 chain I ordered this May came with pins instead of link
    Feb 2006
    I always put the bike in a doorway, sat on the saddle, lock the rear brake, and press down on the pedal. The link clicks into place easily.
    Some remove options:
    1. a quicklink pliers tool.
    2. theoretically, you can squeeze the diagonal ends with pliers. I didn't have much luck with this.
    3. from a youtube video, I made this tool from an old spoke. Cut off the J bend end. Bend the spoke with two pliers. It's exact shape isn't critical. I added a red tape flag so I wouldn't throw it out accidentally.
    Squeeze with pliers at the green arrows.
    Attachment 320537
    Feb 2002
    Very hard to imagine this is the case. As numerous people have shown you, install the link and put pedaling pressure on the chain. The link will snap into place. You may need a tool to get it back apart, but not to install it.
    Reputation: Srode's Avatar
    Aug 2012
    With the KMC quick link, I've never had to lock the back wheel - just roll the chain till the link is on top in any gear and give a pedal a good smack with the heel of my hand and it snaps right into place. Disassembly is easy with the Park tool made for this. I also keep a used link laying around to test fit the chain after cutting to make sure it's what I want before using a new one for final assembly since you aren't supposed to reuse the KMCs on their 11 speed version.
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Actually it wasn't long after that that Shimano gave up on quick links. Until now. This isn't their first go-round with quick links.
    Reputation: Notvintage's Avatar
    May 2013
    But will need the "unlock" tool I believe. I have the KMC tools I got off ebay.
    Jun 2015
    Quote Originally Posted by Notvintage View Post
    In a pinch you can just thread a shoelace around the quicklink and then cinch down to pop it back open.
    Feb 2012
    I doubt you missed anything, I would expect the Shimano quick ling to be single use only.
  1. It came....It came.....
    By Touch0Gray in forum The Lounge
    Last Post: 07-23-2012, 01:06 AM
  2. Shimano 10 speed chain / Connex quick link question
    By DPN in forum Components, Wrenching
    Last Post: 07-11-2008, 07:31 AM
  3. Quick Link in a Campy uber chain
    By IUbike in forum Components, Wrenching
    Last Post: 11-29-2005, 08:03 AM
  4. Quick link or alternative chain for DA10?
    By fallzboater in forum Components, Wrenching
    Last Post: 09-19-2005, 02:45 PM
  5. Quick, Quick, Quick!
    By trek5900cyclist in forum Components, Wrenching
    Last Post: 03-30-2004, 09:41 PM
