Results 1 to 6 of 6
    Jul 2014
    Ultegra Front Derailleur Top Cap
    Ultegra Front Derailleur Top Cap-shimano-ultegra-r8000-fd-r8000-dura-ace-r9100-5801-r7000-front-derailleur-repair-parts-link-cove.jpg
    This small plastic part keeps popping off my front derailleur. How necessary is this piece? It does hold the cable in place, but perhaps I could just trim the excess cable?
    'brifter' is a lame word.
    It's not necessary for the function of the derailleur. If you cut the cable to proper length so you that can actually hold on to it if you need to adjust it for any reason it will hit the crank arm when you're on the small chain ring because it's not being held in the proper position.
    I work for some bike racers
    and a bunch of skateboards
    Jul 2014
    Should I try to get a new one? Or maybe loctite the old one onto the bolt?
    I'd get a new one.
    Reputation: walrus's Avatar
    The cable end cover should keep the cap from being lost, won't keep it on though. I don't think locktite works on plastic. It should snap on firmly, maybe your cap is missing a clamping tab.
    Jul 2014
    Quote Originally Posted by walrus View Post
    The long part that goes into the nut snapped off. Had just put the bike in the trainer and my 18 month old pulled it off the cover link and snapped that part. Ordered a few from ebay (taiwan seller) in case he decides to do it again. Thanks all.
  1. Replies: 4
    Last Post: 07-16-2012, 10:42 AM
  2. Replies: 5
    Last Post: 07-11-2012, 04:11 PM
  3. Replies: 2
    Last Post: 08-25-2011, 04:11 PM
  4. Swap a headset bearing cap cable hanger or a traditional cap?
    By worked in forum Components, Wrenching
    Last Post: 05-13-2011, 04:13 PM
  5. Cap 2 Cap
    By Lifelover in forum Mid-Atlantic
    Last Post: 05-11-2008, 05:59 AM
