Results 1 to 6 of 6
Thread: Ultegra upgrade
    Apr 2013
    Ultegra upgrade
    If i was to have a ultegra 6700 hollowtech 2 double chainset 53/39t 175mm what rear derailleur would i use a medium cage or a small?
    Not a rocket surgeon.
    Reputation: tihsepa's Avatar
    Nov 2008
    Depends on the rear. A short would probably be fine unless you run a really wide rear cassette.
    Reputation: froze's Avatar
    Sep 2002
    Quote Originally Posted by craig3219 View Post
    You should use a short because those front gears are not compact range of gears thus the rear are probably narrower ranged. But it would help to make sure if you knew the rear range.
    Jun 2007
    There are two specs for rear derailleurs - total capacity and maximum cog.
    The length of the cage/arm has to do with the amount of chain it needs to take up, total capacity. I can't remember the formula off hand, but if I recall you add the difference between the chain rings to the difference in the cassette sprockets. Then compare to the capacity of short vs. medium cage. I think short's capacity is something like high 20's, 28 or 29? Meaning even an 11-26-27 (15-16) cassette with a 52/39 (13) is somewhere around the max.
    HOWEVER - the other spec for a rear derailleur is the maximum sprocket size it will accommodate and it's unrelated to cage length. It may actually be functionally a little higher than the stated spec, but regardless, it will be the same for a short and medium cage derailleur of the same lineage. Both are probably spec'd with a 26 or 27 tooth max. So that will be your limitation since either short will accommodate the capacity resulting from the larges sprocket it will handle. If you believe you can use a 28 or even 30 sprocket size with the road derailleur, then that would tip you toward the medium cage, but only if you think you can exceed the stated sprocket size spec. I
    If you want a larger cassette for lower gearing, you'll have to go with a mountain bike derailleur, which will give you both sprocket size and chain capacity. There's some "rules" for using shimano MTB derailleurs with shifters. I know they work seamlessly through 9 speed, but I believe you have to use a 9 speed MTB derailleur with 10 speed road shifters. All I know is that my wife's 9 speed works perfectly with her (either 8 or 9 speed) Deore XT derailleur.
    But it would be very odd for you to be purchasing that crank if you want low gearing, so disregard that.
    I hope this makes some sense to you.
    May 2011
    Camilo sums it up well. That said, though I can't find the "official" capacity and max cog for it, I've used a 6700 short-cage rear derailleur with an 11-28 cassette and a 53/39 crankset many times with no problems.
    Not that it matters in this instance, but my crank-arms are 175mm too.
    Well, you know, that's just, like, your opinion man. - The Dude
    Mar 2013
    Brand New 2013 Shimano Ultegra RD-6700A-G SS Rear Derailleur | eBay
    U can use the above short cage RD for the newest 12-30T cassette.
  1. Upgrade to Ultegra Di2?
    By MyaLover in forum Giant
    Last Post: 01-23-2013, 10:18 PM
  2. 105 triple upgrade to Ultegra FD and RD
    By dlhillius in forum Components, Wrenching
    Last Post: 08-04-2011, 09:04 PM
  3. ultegra 9 to 10 upgrade Qs
    By brujenn in forum Shimano
    Last Post: 08-03-2009, 02:21 PM
  4. Ultegra 10 Upgrade ??
    By mcoven in forum Components, Wrenching
    Last Post: 10-14-2005, 12:40 PM
  5. Tiagra Ultegra upgrade
    By Zeke in forum Components, Wrenching
    Last Post: 10-24-2004, 07:04 PM
