Results 1 to 4 of 4
    May 2013
    Updating old freewheel to freehub + SRAM X5
    Howdy,
    I have an older ('83 vintage) 18 speed friction shift road bike with the original shimano components. I'd like to upgrade the rear derailleur to the 2012 SRAM X5 as part of a DIY electric shifting project. The project requires that particular model. Yes, I am being dragged kicking and screaming into the future, bypassing indexed shifting altogether...
    I understand I'll need to replace the freewheel with a freehub, but I'm not sure what would be compatible with my original hub and the X5. I can take some clearance measurements if it helps.
    What else must I replace? I understand friction shifters should work fine, if the e-shift project does not work out. Will the new cassette be compatible with my chain and front gears? Replacing the chain is not a concern (it is due), though I would prefer not to replace the front gears (yet).
    Perhaps a better alternative would be to find a used modern rear wheel? I am still running 27" wheels.
    My impression is either a mid or long cage derailleur should work.
    Thanks!
    'brifter' is a lame word.
    i'll just throw this out there for starters. you current hub is in NO way compatible w/ modern cassettes. there is no way to put one on this hub. you'll need a new rear wheel. which is going to be wider (130mm vs 126mm), but it's no big deal w/ a steel frame.
    secondly, you'll need a new chain to match the drivetrain you install on the rear of the bike. you must match the chain to the cassette.
    2010 Cervelo T1 sprint bike
    Ruger 10-22TD
    Smith&Wesson M&P 15-22
    Smith&Wesson M&P 9
    oh, those belong in another forum
    Feb 2002
    Quote Originally Posted by Glug View Post
    Howdy,
    Thanks!
    This project can easily be described in four words: "black hole for money." You would in nearly every case be ahead of the game to sell this bike and combine the proceeds with the money you would have spent trying to bring it forward 30 years and buy a few years old used bike. Projects like this often turn into a money pit where "just one more thing" is needed to get things working right. But then things don't work right, so you need "just one more thing." Reconsider your plan.
    Banned forever.....or not
    Aug 2002
    Save your money. Your frame is built for 27" wheels.
    Dogbert.
    I>U
  1. SRAM freehub body?
    By filly in forum Wheels and Tires
    Last Post: 08-28-2009, 07:17 AM
  2. SRAM Chain on Uniglide Freewheel
    By jwgd in forum Retro-Classic
    Last Post: 07-29-2009, 09:30 AM
  3. Mavic repair freehub/freewheel bushing
    By bikewcm.com in forum Components, Wrenching
    Last Post: 03-22-2009, 02:20 PM
  4. Sram cassettes on dura-ace freehub. Please Help
    By swimmingskibble in forum Components, Wrenching
    Last Post: 02-07-2008, 07:56 AM
  5. Does my freehub (or freewheel) need lubrication?
    By S2H in forum Components, Wrenching
    Last Post: 12-11-2006, 11:44 AM
Sea Otter Classic
Contest
