Results 1 to 7 of 7
    Sep 2016
    Upgrading from Tiagra to Ultegra R8000
    I am upgrading from Tiagra to Ultegra R8000. I am planning on doing all the work myself. The only part I am doubting I can handle is the removal of the BB71-41 bottom bracket.
    Would it be advisable to replace the bottom bracket (3 years old) at this time?
    Sent from my SM-G955U using Tapatalk
    Apr 2006
    Unless it's giving you a problem, there is no need.
    Sent from my SM-G950W using Tapatalk
    Feb 2002
    Quote Originally Posted by jsebastianorozco View Post
    Echoing goodboyr, it's not obvious what you would gain from this expenditure. Replace things as they wear out or cease to operate properly.
    Regards the BB, age means nothing. If you didn't ride the bike for three years then there wouldn't be a reason to replace. If you rode 10K miles per year, then maybe it would be worn out already (or maybe not). If the BB turns smoothly with no wobbles, it doesn't need to be replaced.
    'brifter' is a lame word.
    You'll need an 11 speed compatible rear wheel.
    I work for some bike racers
    and a bunch of skateboards
    Sep 2016
    Thanks all for the input, no issues with the BB. Just wanted to make sure it wasn't a situation where the BB wears with he old crank such that the new crank would fit poorly.
    I have a 10 speed cassette and when I purchased the bike. Seller confirmed it was fully upgradable to an 11 speed cassette as that was always my intention.
    It is a giant defy advance.
    Reputation: Lombard's Avatar
    May 2014
    If it's a press fit BB and there are no problems with it, don't touch it! If it aint broke..............
    Not in the way you are worried about. Any wear issues would be evident with the old cranks not hidden by them.
  1. Replies: 6
    Last Post: 07-12-2018, 07:59 AM
  2. Shimano Ultegra R8000 drivetrain missed the Boat...
    By factory feel in forum General Cycling Discussion
    Last Post: 04-09-2018, 11:07 AM
  3. Shimano Ultegra R8000 officially announced
    By cobra_kai in forum Components, Wrenching
    Last Post: 06-13-2017, 05:19 AM
  4. Upgrading shifters from tiagra to ultegra
    By keithkris in forum Components, Wrenching
    Last Post: 04-12-2011, 10:24 AM
  5. New Bike Q's: C-Dale R8000 or Six 13
    By Surly in forum Bikes, Frames and Forks
    Last Post: 05-09-2005, 10:47 PM
