Results 1 to 25 of 40
    Apr 2008
    weird derailluer position
    This is the original chain on my 1997 Hardrock 7 speed. A few years ago I took the chain off to clean and ended up taking two links out in the process. Since then I have always wondered why the chain, when in the small/small set up would look like this. I have attached 2 images. As I said, this is the original chain minus 2 links. I know the first answers are going to be "the chain is too long" but is it? Was I supposed to "wind" up the cage or something when I put the chain back on? Its never been a problem riding though, go figure. Anyway, here are the images:
    weird derailluer position-drailup.jpgweird derailluer position-deraildown.jpg
    I am probably the last person to have received an email from Sheldon Brown! A very nice gentleman.
    2008 Specialized Roubaix Elite Triple
    105 Shifter/derailleurs
    FSA Gossamer Triple MegaExo
    BWW Blackset Race 11 wheels
    Continental Gators 25c
    Kool Stop Salmon brake pads
    Cateye Strada Double Wireless CC-RD400DW
    Sigma PC-9 HRM
    RADBOT-1000 rear strobe flasher
    Blaze 1/2w LED headlight
    Oct 2013
    That chain is too long!
    BANNED
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by FreeRojo View Post
    The chain is too long.
    Yes it is.
    No idea what that means.
    Have you ever rode in the small/small? Cause if you did it wouldn't work so well and would make a lot of noise as the chain dragged along the chainstay.
    Apr 2008
    Okay, the chain is TOO long! :-) I will replace ASAP with a new, properly sized chain.
    Sigma PC-9 HRM
    tlg
    tlg is offline
    May 2011
    If the chain isn't worn, you don't have to replace it. Just shorten it.
    What the what???
    Jul 2009
    I would suggest taking the bike to your LBS to help get you squared away. No offense intended, but if you didn't see that the chain was too long to begin with, do you trust yourself to properly shorten it?
    The Law of Headwinds states: If the ride out is easy, you better have something saved for the turn...
    a real member's member
    Jul 2016
    i use sheldon's advice and never ride in the small/small nor the big/big combos.
    Apr 2008
    As I had mentioned, this is how Specialized put it together 20 years ago.
    Sigma PC-9 HRM
    Oct 2013
    hOOOO, sure!
    BANNED
    Russian Troll Farmer
    Sep 2016
    I doubt this is the way Specialized built it. For one thing, I can see a TON of space between the front derailleur and the large chainring; this tells me that the rings are not stock, and quite possibly, neither is the crankset. If you had the correct ring that this model came with, you probably wouldn't have an issue.
    "L'enfer, c'est les autres"
    Apr 2008
    Your talking through your hat. These are the original components from the day I bought the bike in 1997.
    Sigma PC-9 HRM
    'brifter' is a lame word.
    Quote Originally Posted by blackfrancois View Post
    Sheldon's old advice that no longer applies in this case? There is NOTHING wrong w/ big/big when needed. ALL modern drivetrains are designed to do big/big w/ no issues. Well, maybe slightly accelerated wear on drivetrain parts, but it will work if everything is properly set up and there is no reason not to do it when needed.
    I work for some bike racers
    and a bunch of skateboards
    Explain how a larger big ring would change anything here.
    Oct 2013
    I think I discovered the problem, on the second picture his rear tire is going 20mph reducing the slack in the chain. In the first picture his rear tire is stopped, so there is no spinning to reduce the slack in the chain. ~
    BANNED
    Reputation: Lombard's Avatar
    May 2014
    This certainly is a strange situation if you took two links out of the chain. Looking at your derailleur pulleys in both pictures, it doesn't look like there is anything wrong with your derailleur spring. In the small/small, the cage is fully retracted. In the large/large, it isn't extended as far as I would expect.
    The only thing I can say is the chain is too long.
    May 2014
    When is it ever really needed?
    Banned forever.....or not
    Aug 2002
    When you are charging up a hill, out of the saddle in the 53, in the 21 of a 12-23, and you need to sit down and spin a little, it's better to use the 23, rather than drop it all the way to a 39x17.
    Dogbert.
    I>U
    Sep 2016
    It would take up a few more links......
    Apr 2008
    Finally someone is clueing into this. This chain is original, tons of hard miles, 20?years old. 8 years ago I stripped the bike down to the bearings and put it back together. In the process I removed the chain and mangled the cut and costing me 2 links. I took the pulley cage apart to clean. Everything went back together well. It's a cunundrum, can a chain get so stretched even after missing 2 links to droop like this? The bike has run flawless all this time. I am picking up a new chain tomorrow and will properly size the chain per Park Tool guidelines, hope fully the new pictures will look differently. Thanks :-)
    Sigma PC-9 HRM
    Apr 2008
    Sigma PC-9 HRM
    Reputation: velodog's Avatar
    Sep 2007
    Is that a triple, and do you have it in the granny and the small cog?
    It doesn't look like it's in the small ring, and if it's in the granny ring that may be asking a bit much of the derailleur.
    Too old to ride plastic
    Pathlete and Pedalphile
    Reputation: redondoaveb's Avatar
    Jan 2011
    According to the bikepedia link he provided it is a triple. Somethings not right though. Original chain (should have been sized right). Took 2 links out and re-installed and now is too long.
    If you try to fail, and succeed, which have you done?
    Oct 2013
    That is not the original chain, that is just crazy and u are losing your mind.~
    BANNED
    Think again. The chain is only too long in the small/small. The big ring has nothing to do w/ anything here.
    No, chains don't stretch. They wear, and they elongate, but it's not stretch.
    If this bike is indeed as original then the derailleur on it will wrap the chain successfully if the chain was sized properly to begin with. If the OP actually removed 2 links at some point and the bike was built like that, then yes...chain is/was too long.
  1. Normal position vs drop bar position
    By nolight in forum General Cycling Discussion
    Last Post: 12-10-2012, 03:37 AM
  2. Weird seat position/handling problem
    By Davoosie in forum General Cycling Discussion
    Last Post: 03-24-2008, 02:51 PM
  3. Ultegra long cage derailluer
    By lancezneighbor in forum Components, Wrenching
    Last Post: 09-09-2004, 05:03 PM
  4. Rear Derailluer malfunction
    By Nathan_P in forum Retro-Classic
    Last Post: 08-19-2004, 06:56 AM
  5. Climbing position / saddle position
    By brblue in forum Racing, Training, Nutrition, Triathlons
    Last Post: 07-28-2004, 12:28 PM
