Results 1 to 25 of 30
    Apr 2009
    Why am I so inept at mounting clincher tires?
    Tried to mount Continental GP4000S on Campagnolo Eurus wheels last night using Challenge latex tubes. I was looking forward to mounting the Continentals over my last tires (Vittoria Zaffiro Pros) because I heard that the GP4000S tires were much easier to mount by hand. I understand the preferred technique, it's just that I can't seem to execute the preferred technique. My thumbs are very sore this morning from trying to roll tire bead over the rim. As added insult, I watched a Campagnolo video on YouTube (CAMPAGNOLO 2WAY FIT WHEELS CLINCHER TIRE INSTALLATION - YouTube) for mounting clincher tires, and the guy does not struggle one bit getting that Tioga tire on . Ego was crushed even further by a small Italian man. As a point of reference, I built my bike on my own, so I'm not mechanically inept (the bike hasn't fallen apart...yet).
    As a secondary question, I went add a bit of air to the latex tubes to give them some shape, and noticed something odd. Both tubes initially inflated uniformly, but then one spot started to balloon out like a, well, balloon. It looked kind of like a snake that had swallowed a mouse. Normal with latex tubes?
    Reputation: minutemaidman's Avatar
    Jun 2010
    Campagnolo rims, in general, are quite famous for being hard to mount tires onto. I have an old pair of Lamda Strada Vs that are super hard to get tires on. I, and many others, have found that Vittoria makes some of the easiest to install tires around. I use the Rubino Pros and the Diamante Pros on my bikes, and have found this to be the case. Vittorias are the only tires I have been able to mount on the Campy wheels. Good luck. I dont know if this is true of your wheels or not, I have no experience with them. Dont know about the latex tube either.
    A while back I decided to ride a bike as often as possible. These are my observations from the saddle, one pedal stroke at a time, on my way to being a better cyclist.
    Reputation: JCavilia's Avatar
    Sep 2005
    Are you doing it right, working the bead down into the rim center channel to get slack?
    This might help.
    What Every Cyclist Should Know About Flat Tires
    As for the latex tubes, that is normal. Ordinary toy balloons are made of the same stuff. So don't overdo it, though they can stretch surprisingly far before bursting with a tremendous sound.
    Apr 2009
    Quote Originally Posted by JCavilia View Post
    This might help.
    This is pretty much the technique that I am using.
    Reputation: Golfguy's Avatar
    Nov 2010
    I didn't have a real hard time getting my Hutchison Atom tires onto my new Campy Zondas recently. Haven't used Contis lately.
    Kestrel Talon Road, Campy 10, Zonda wheels
    Litespeed Firenze, Campy 10, Joe Young Custom Wheels
    Nashbar Generic single speed, Khamsin wheels
    Jan 2009
    One key to easy installation is to work the second side toward the valve. There's some debate here, but here's why I do it this way.
    The rim has it's smallest diameter at the center, so that's where you can pull some slack around. The valve keeps the tire from going to the deepest part of the well, costing you that slack you so badly want.
    However, since the tube is usually a bit thicker at the valve it's important that you finish by pushing the valve deep into the tire so it drags the tube out from where it may be trapped under the bead. Then pull the valve back out to seat it properly.
    Lastly, roll the tire up over the rim using the strongest part of your hands. Push the bead using the thick pad at the base of the thumb, rather than your fingers or the tip of your thumb.
    fb
    www.chain-l.com
    Solving any problem requires understanding the underlying cause
    Nov 2011
    Google "bead Jack"...thank me later...
    formerly "backinthesaddle"
    Strava is Latin for 'bench-racing"
    Reputation: looigi's Avatar
    Nov 2010
    In my experience, lubricating the tube and tire bead with talc makes mounting and unmounting much easier and lessens the chance of pinching a tube.
    Sep 2005
    Quote Originally Posted by looigi View Post
    My experience, too. And getting baby powder all over the place makes you smell much nicer, too ;-)
    waterproof*
    Reputation: Creakyknees's Avatar
    Sep 2003
    I have a VAR tire lever in my saddlebag at all times. I use Conti tires on Campy rims.
    * posted by Creakybot 2013 all rights reserved.
    * not actually waterproof.
    Reputation: Trevor Ash's Avatar
    May 2005
    Your first question comes up a lot. It boils down to "I can't install my tire" and it's common to get these responses "I only need my fingers/thumbs, you're doing it wrong idiot".
    The truth is, sometimes they're right. Many (though i'm sure not all) of today's rims/tires mate well.
    But the other truth is that there really are incompatible tire/rim situations out there. It's interesting that someone mentioned a lambda rim. I have a set of older campy lambda aero rims and they are definetely a pain!
    These "incompatible" mixes are where you need to employ all techniques and possibly some tools. The kind of tools that people who never experienced these situations think you're just an idiot.
    Once you realize you're not getting it on with hands, and a plastic tire lever alone isn't going to cut it. The next step I take is to use water as a lubricant. I've used Window before as well but I prefer water. Don't worry, it'll dry out and it's not going to rust your spokes/nipples unless you use the water from out in the street
    If water alone doesn't cut it, I heat up the tire. There are all kinds of methods to do this. Figure something out. Warm tire + some lubricant + all the other techniques (and perhaps a metal tire lever for an extreme situation) will likely get the toughest jobs done.
    Note: I've never tried talc/baby powder but if that works better than water then by all means! I just don't have that around the house.
    Militant commuter
    Reputation: SilverStar's Avatar
    Jan 2008
    I learned a trick from someone on this forum or another...put the new tires in the clothes dryer for a few minutes to heat them up and they will go onto Campagnolo rims a lot easier. Once the tires have been mounted and inflated/used for a while, they'll be a lot easier to get on/off in the future.
    "Luminous beings are we...not this crude matter!"
    Reputation: GRAVELBIKE's Avatar
    Sep 2011
    Get some thin, Mechanix-style gloves and wear them when you're mounting stubborn tires. Less risk of pinching your skin between the bead/rim, and the extra grip helps mounting the tire easier.
    Lube the bead with a mixture of water and dish soap. You don't need to go apesh*t with the soap, just use a little bit. This works wonders with tubeless MTB tires which can be pretty difficult to mount/seat.
    Don't use your thumbs. Roll the tire onto the rim using the "heel" of your hand (wearing the aforementioned gloves helps).
    GRAVELBIKE.COM - ride everything
    Resident Curmudgeon
    Nov 2005
    I teach bike maintenance & surviving mechanical breakdowns for our club of 260+.
    Whoever said that Campy rims were difficult to mount tires on is absolutely correct. They're a real $%^%! Here's what I'd do. Dust the inside of the tire with baby powder. It acts as a dry lube which helps the tube slide easily inside the tire. Lube the tire beads with soapy water from a spray bottle as you're mounting the tire. Put a little air in the tube-just enough so it's round. One or two strokes of the pump will be more than enough. Fit the tube in the tire lining up the stem with the label on the tire. Put the wheel on the ground, leaning the top edge of the rim against your knees. Start mounting the tire/tube combination by pushing (NOT PULLING) the stem through the hole in the rim. Using your thumbs work the tire onto the rim starting from the top, going down both sides as far as you can. When the resistance becomes too great flip the wheel over so the mounted side is on the floor. Now might be a good time to apply a little soapy water spray. Careful, though. I'll also make your hands slippery. Keep the unmounted bead away from you, pulling it on with your fingers. Try to measure progress an eighth in. at a time. Spray more soap if you need it. If it gets so hard you just can't do any more take this..................http://www.amazon.com/Crank-Brothers.../dp/B001BIZARI TA DAA from your tool box. This tool works exactly like the kind the nice folks at the tire store use to mount your car tires. It telescopes out. Snap the forked end on the axle & hook the other end over the rim. Spray some soap & pull the tool toward you using 2-3 fingers placed against the tool on the rim.
    When it snaps on jump up and say, HOLY $HIT! I KNEW I COULD DO IT. Then inflate the tire, put the wheel on the bike, & have a beer.
    This is an abbreviated explanation. I may have left out a step, but it's late, I'm old, I'm a slow typer, & I'm not going to go over this again.
    You know that little thing in your head that keeps you from saying things you shouldn't? ......Yeah, I don't have one of those..
    Frog Whisperer
    May 2003
    I have 2 sets of campy wheels....and yes indeed they can be REALLY nasty to mount a clincher on....I am no noob to mounting tires and the last set of new Michelins I mounted up on my Khamsins, I ruined one tube (beyond patching) and 3 tube wounds that needed to be patched! (and 2 broken plastic levers) AND THAT WAS IN MY LIVINGROOM!!!!! FORTUNATELY after they have been on and inflated to 90 psi for a while, replacement by the side of the road is at least a possibility!
    Of course I'm sure...that doesn't mean I'm right......
    Quote Originally Posted by nOOky
    If you're not living on the edge you're taking up too much space!
    Quote Originally Posted by Opus51569
    Maintaining a water feature is like dating a crazy woman. It seems like a good idea at the time... beautiful to look at... but then you make an innocent, offhand remark about her turning into her mother and she tries to stab you with a fork.
    We ride for friends, we ride for family, we ride for strangers...2013 24 Hours Of Booty
    Reputation: zmudshark's Avatar
    Jan 2007
    I do what Mr. Versatile does. The Crank Bros tool goes into the seat bag when riding a bike w/Campy wheels.
    Thinnest rim tape possible also helps.
    I love tubulars more each day.
    Reputation: thebikingcello's Avatar
    Feb 2011
    It gets fun after a while. Make a game out of it and see if you can beat your last time.
    Bikes:
    Felt F95 2011: my main road ride
    Jamis Dragon 29 Sport 2011: my main MTB(Steel is Real)
    Raleigh Record 1976: Single speed in the making
    Possible Fuji cross frame I might get... and paint...
    Nov 2005
    Thumbs up
    Quote Originally Posted by MMinSC View Post
    this. its a magic tool.
    and another thing to take into consideration is the thickness of your rim strip. the thinner it is, the more room you have to work with and easier the tire will go on.
    Hide Age and DOB
    May 2007
    While I have never mounted a tire on Campy rims, I have mounted Conti's on several rims and they are always a PITA. This especially true of boxy rims like an old Mavic MA3.
    E’ fatto espresso divieto di partecipare alla manifestazione con biciclette che non possiedano i suddetti requisiti.Ogni tentativo di farlo a mangiare un piatto di grandi dimensioni di 3 settimane la polenta e in genere di divertimento, soprattutto se egli è straniero.
    Sep 2011
    Have you ever mounted a Continental trainer tire??? I've had to mount 3 in my lifetime and it was 3 too many, The first one took me 2 days and 6 tubes to get right and It hasn't come off that rim since!!!!
    Pinched finger, bloody nails...soar throat from all the cursing...they are the pits. Black or yellow makes no difference! Bontrager, Mavic, Zipp, Hed, Stars...it doesn't discriminate, it hates them all. Worst experiences ever!
    p.s. Talk/soapstone dust works wonders, and leaves your hands with more grip and less slip than soapy water.
    Frog Whisperer
    May 2003
    fwiw...windex is an excellent lubricant for this type of thing (and getting stuck rings off of fingers) it is alkaline enough to be slippery.
    Frog Whisperer
    May 2003
    Quote Originally Posted by LeShaghal View Post
    btw don't you just love it when you fold your fingernail back so it touches the knuckle!
    Apr 2011
    Quote Originally Posted by savechief View Post
    I recently went from Zaffiro Pros (easy to install) to Continental GP4000S. What a PITA it was! Yes, GP4000S is real tight. I hope they never go flat on the road because it will take too much to fix it.
    Mar 2011
    I don't have any Campy rims but I have two road bikes and four sets of Shimano wheels all fitted with Conti GP4000S tyres and find them a piece of cake to fit. Friends marvel that I even rotate tyres from front to rear to even out the wear.
    I use baby powder on the tubes to help them seat evenly.
    Feb 2002
    Just say no to rotation
    Quote Originally Posted by Cut.Aussie View Post
    A better practice is to let the rear wear out and move the front to the rear, putting a new tire on the front. You always want to have the best rubber on the front.
  1. Mounting tubeless tires...
    By pablotn in forum Wheels and Tires
    Last Post: 02-27-2011, 05:07 PM
  2. Mounting Tires
    By dunksmooth in forum Wheels and Tires
    Last Post: 02-26-2010, 07:03 PM
  3. Help mounting tires!!!
    By silver6 in forum Wheels and Tires
    Last Post: 07-21-2009, 04:56 PM
  4. Tires not mounting correctly!
    By crumjack in forum Wheels and Tires
    Last Post: 02-28-2007, 02:55 PM
  5. mounting cross tires
    By noavg55 in forum Cyclocross
    Last Post: 03-02-2004, 03:29 PM
