Results 1 to 13 of 13
    Mar 2007
    Why are shimano road brake pads marked L and R
    To me, these pads look like they are symetrical top to bottom, so does it really matter which shoe you put the pads in? In other words, does a left pad have to go in the left shoe?
    Sep 2002
    They have a subtle curve to they have both a left and right and a front and back.
    Mar 2007
    When you say front and back, do you mean front brakes (on front wheel) and back brakes (on back wheel)? If yes, I've never noticed this when I've bought the pads before. I only see L and R on them. Where does it say front and back?
    Sep 2010
    Quote Originally Posted by dougmint
    The pad holders have a front and back. If you reverse them braking will pull the pads out of the holders.
    Also, the slots in the pad are directional for cooling and venting water. Put them backwards and they won't work as well and probably squeal.
    Reputation: WheresWaldo's Avatar
    Nov 2005
    Quote Originally Posted by rx-79g
    No the shoes are not marked front/back nor are they marked left and right, only the pads are marked. It shouldn't take a rocket scientist to figure out that you just reverse the shoes between front and back and then all four "point" the same direction. Pads are marked because they have a slight taper as well as a curve.
    What slots are you referring to? Some pads only have slots perpendicular to the braking surface and some pads have no slots at all. The slots are probably about as useful as tread is on a 22mm wide tire. I think you just are making shite up!
    'brifter' is a lame word.
    the pads are marked L and R because
    1) they have a slight curve, and...
    2) there are slots in the back for the small bolt that holds them in the pad holders. that slot (and the shape of the pad) defines 'front' and 'back'...
    the pad holder is 'closed' at the front, and the security bolt is at the back. pretty basic, really.
    all you have to do is look at the holders, and look at the pads. if you still don't get it, you shouldn't be playing w/ tools.
    I work for some bike racers
    and a bunch of skateboards
    Sep 2010
    Quote Originally Posted by WheresWaldo
    Go ahead and try it, smartypants. CX and I know what we're talking about, and have done the work.
    You don't and obviously haven't.
    Jun 2006
    if you put them in backwards you will speed up when you grab the brakes....
    Reputation: PlatyPius's Avatar
    Feb 2009
    Quote Originally Posted by cxwrench
    ^^^ This.
    Other countries need to stop hatin' or we'll unfriend them. - Christine
    Apparently I left my reading comprehension glasses in my ass. - DrRoebuck
    Still, it felt great and I felt like I was sitting on some kind of vibrator -Touch0Gray
    Apr 2017
    I still don't get it, but am playing w/ tools.
    You shouldn't let your rage consume you.
    Quote Originally Posted by nimetonmaili View Post
    Are you a SJW as well? This thread is 6 years old and you posted just so you could say this?
    Apr 2017
    I actually enjoyed bleeding my disc brakes, even though it was my first time and made lots of mistakes.
    Reputation: Lombard's Avatar
    May 2014
    Do you have an organ donor card?
    -- Warren Buffett
