Results 1 to 5 of 5
    Apr 2007
    will anatomic bars fit on a nitto stem
    will this guy
    work with this non face-plate stem
    thanks
    hello
    Reputation: roadfix's Avatar
    Jun 2006
    I've done it. You really need to pry open the clamp and muscle the bar around the sharp bends. Your bars will end up with gouge marks.
    SurlySteamrollerLitespeedClassicBianchiPista
    DeanColonelSurlyLongHaulTruckerKonaKu
    LitespeedFirenzeCinelliOlympic
    wim
    wim is offline
    Feb 2005
    Quote Originally Posted by blantonator
    will this guy work with this non face-plate stem thanks
    As said, you may have to work at it a bit to bring the stem over the sharp bends and those ergo humps or whatever they are. But all that's assuming the bars are 26.0 mm diameter in the stem clamp area to fit the Dynamic's 26.0 mm clamp. If the bars are 31.8 mm in the stem clamp area ("oversize"), forget it. But perhaps you knew this already.
    Reputation: JCavilia's Avatar
    Sep 2005
    Yeah, it'll work if the stem is the right clamp size. And if you do it right you should not damage the bar at all. You wedge the clamp open as much as possible (don't bend it, though), and then carefully work the stem onto the bar. It's easier if you do it off the bike, so you can freely rotate the stem. At each bend and crimp in the bar, there will be a precise angle at which the stem will move most freely. You just move it a little at a time, rotating as necessary. Anatomic-bend bars were introduced when the only stems in use were non-faceplate quill stems. Most are compatible.
    Apr 2007
    the bars are 26.0... thanks!
Sea Otter Classic
Contest
