Results 1 to 25 of 32
    Reputation: AJ88V's Avatar
    Nov 2012
    Will a SRAM Yaw 22 FD work with a 10 speed setup?
    Or are the throw and cage spacings incompatible with a 10 speed chain/wheel?
    Reputation: AvantDale's Avatar
    Dec 2008
    Should still work...you still only have two rings in the front.
    Sep 2011
    Works fine with my 2011 Force 10 speed group
    Sep 2011
    Just make sure you watch the video several times before you attempt to install. Not rocket science but the procedure is completely different than anything you may have installed in the past from any maker
    Nov 2012
    Thanks, folks.
    Next question: Is it worth it? I currently have a Rival FD on my 10-speed group, but have never liked the way it shifted. The trim function works fine. Just found a good price on the Force 22 Yaw and thought it might be worth a try.
    So is it worth it? Thx.
    Dec 2008
    I've read that it does work better. You'll lose the trim feature in your current levers.
    Reputation: stevesbike's Avatar
    Jun 2002
    what's the difference between a 10 speed Yaw front derailleur and an 11 speed? Is there any difference re the amount of movement?
    Nov 2012
    Quote Originally Posted by stevesbike View Post
    That's what I was wondering. I just looked at the Exogram crankset and the "22" and regular 10-speed versions have the same weight, but there were no dimension changes that I could discern.
    A Midwesterner In Europe
    Mar 2005
    Yes.
    I never liked the original SRAM FD's. I had been using a 5700 series 105 FD for awhile and I just swapped it out for a Force 22 FD.
    Here's the setup I'm running.
    SRAM Force 10spd shifters (2011?)
    Shimano Ultegra chain 6701
    Rotor crank with Stronglight CT2 chainrings (52/36)
    SRAM Force 22 FD
    It works really really well. Such a difference in front shifting quality.
    Nov 2012
    Quote Originally Posted by j.king View Post
    Yes.
    SRAM Force 22 FD
    This is exactly what I was looking to hear. The Force 22 Yaw dérailleur looks like a real bargain.
    Thanks to all for your responses!
    Jun 2005
    Wouldn't the cage be narrower on 22 front der since its intended for a thinner 11 spd chain?
    Nov 2012
    Quote Originally Posted by farva View Post
    This is what I was concerned about too. From Wikipedia
    Sizes
    Exploded view of a few bicycle chain links
    The chain in use on modern bicycles has a 1/2" pitch, which is ANSI standard #40, where the 4 in "#40" indicates the pitch of the chain in eighths of an inch, and metric #8, where the 8 indicates the pitch in sixteenths of an inch.
    Width
    Chains come in either 11/128", 3/32", 1/8", 5/32", or 3/16" roller widths, and this is also the internal width between the inner plates. Chains with 1/8" wide rollers are used on bikes with a single rear sprocket: those with coaster brakes, hub gears, fixed gears such as track bicycles, or BMX bikes. Chains with 3/32" wide rollers are used on bikes with derailleurs such as racing, touring, and mountain bikes.[7] Fixed sprockets and freewheels are also available in 3/32" widths so fixed-gear and single-speed bikes can be set up to use narrow and lighter 3/32" chains. Finally, chains with 5/32" wide rollers are used on freight bicycles and tricycles.
    With derailleur equipped bicycles, the external width of the chain also matters, because chains must not be too wide for the cogset or they will rub on the next larger sprocket or too narrow that they might fall between two sprockets. Chains can also be identified by the number of rear sprockets they can support, anywhere from 3 to 11, and the list below enables measuring a chain of unknown origin to determine its suitability.
    6 speed - 7.8mm (all brands)
    7 speed - 7.3mm (all brands)
    8 speed - 7.1mm (all brands)
    9 speed - 6.6 to 6.8mm (all brands)
    10 speed - 6.2mm (Shimano, Campagnolo)
    10 speed(Narrow) - 5.88mm (Campagnolo, KMC)
    10 speed(Narrow, Direction) - 5.88mm (Shimano CN-5700,CN-6700,CN-7900)
    11 speed - 5.5mm (Campagnolo, KMC, Shimano CN-9000)
    The chain width difference is pretty small, 0.33 mm = 0.013". In fact, that's so small that I wonder if an 11 speed chain might work just fine on a 10-speed setup, with the benefits of easier adjustment and quieter operation.
    As to the front derailleur, from Sheldon Brown's website 6-speed, 7-speed, 8-speed, 9-speed, 10-speed, 11-speed?:
    Derailers-Front
    Front derailers don't generally care how many gears you have in back, though models designated for higher numbers of speeds may have slightly narrower cages , so they might be a bit more fussy in adjustment/trim when used with wider chains.
    Front derailers are generally 2- or 3-chainring specific.
    "Triple" front derailers have a wide, shaped inner cage plate. They generally work OK with double chainrings as long as the step between the chainring sizes is matched to the derailer.
    "Double" front derailers work well with triple chainrings as long as the step between the outer and middle chainrings is only 4 or 5 teeth (as in a half-step system). If the step is larger, shifting from the small to the middle chainring will require some care and skill. In fact, you may need to upshift all the way to the big chainring, then jump back down to the middle.
    Later, the inestimable Mr. Brown writes:
    Chainrings/Cranks
    Old Chainrings, New Chains
    There is a lot of confusion about the compatibility of narrow 9- and 10-speed chains with older cranksets. Shimano says you should replace the inner chainring(s) with specially designated 9- or 10-speed ones, but then they're all too eager to sell you stuff, whether you need it or not.
    These chainrings have the teeth slightly farther to the right than the older chainrings to work a little better with the narrower chains. There is no difference whatever in the crank spiders.
    The manufacturers also are concerned about clueless users. The worst-case scenario is that you will be riding along with the bike in its highest gear (large front, small rear) and then for some bizarre reason shift down in front before downshifting in the back. (There is no shift pattern in which it is reasonable to shift in this sequence.) [Not with a 9- or 10-speed cassette, to be sure -- John Allen] If you do shift this way, there's a small chance that the chain might "skate" over the edges of the teeth for maybe half a turn.
    In practice this "problem" almost never materializes. Many, many cyclists are using 9- and 10-speed chains with older cranksets and having no problems whatever.
    New Chainrings, Old Chains
    Going the other direction, using wider chains with chainrings intended for narrower chains is not generally a major problem if there's only a one- or two- generation difference. The only problem you might run into is that the chain will be more liable to rub on the inside of the bigger chainrings in the small/small crossover gears, gears you shouldn't be using in any case.
    Take all that together and it sounds like the front derailleur should work just fine. An 11-speed chain sounds like it would work fine too. I've done a little web surfing and there is some evidence that everything should work, but I'd do a little more searching before trying such a switch.
    Nov 2012
    For reference: Just bought the Force 22 Yaw FD off Amazon (through Xtreme Bike & Sport) for $56.70 shipped (including chain spotter!).
    Amazon.com: SRAM Force22 Braze-On Front Derailleur: Sports & Outdoors
    That's on par with an Ultegra FD and cheaper than a Dura Ace that some people have used when dissatisfied with the standard, non-Yaw SRAM FDs.
    Can't find the link now, but one of the big cycling mags tested all sorts of combos and estimated you got 90% of the benefit going Yaw FD with regular crankset combared to Yaw FD and Red crankset.
    EDIT: Found it! It works! We test SRAM Red backwards compatibility
    Mar 2005
    Quote Originally Posted by AJ88V View Post
    Off topic but...I know the new Dura-Ace will shift perfectly fine on a 10spd cassette everything else being 11 spd.
    As far as the 11 spd Force 22 FD cage width there is nothing to be concerned about. Since installing the Force 22 FD and having put some decent km's on it I've had not a single issue. It works great you'll love it.
    Aug 2011
    FYI: there's another thread going on this and i made some comments regarding my experience trying this over there. LINK
    B05
    B05 is offline
    Jul 2011
    My current set up of all 2011 Rival + 2012 Red crank is going to be changed to:
    - Ultegra 6750 crank
    - SRAM Force 22 FD
    Should work correct?
    Nov 2009
    Yes, it will work fine. I run SRAM Red 10 speed with Red yaw 22 fd along with dura ace 7950 crankset and have no issues. It does shift better in the front, but honestly my dura ace 7800 bike has better front shifting.
    B05
    B05 is offline
    Jul 2011
    Quote Originally Posted by JSWhaler View Post
    would you recommend a 7800 FD then?
    any chain rub on the yaw 22 fd?
    thanks!
    Jan 2009
    Yaw 22 FD
    How much better does it shift?
    Nov 2009
    I've used a DA. 7800, sram force, and now the newest YAW fd. The YAW works the best and I'd just get it and be done with it. I only get chain rub if I cross chain, otherwise no issues. It shifts well, just not as good as shimano IMO. However, I love the rear shifting.
    Jan 2015
    shredmore
    Based on measurements with a dial caliper, the Red 22 front derailleur cage is approximately 0.05 inches narrower at the front end than the Red 2012 (for reference purposes, 0.05 inches is approximately the width of the metal used for the inner part of the cage). This narrower width carries through to the rearmost cage pivot point. The measured width from the middle of the rear portion to the back end of the Red 22 cage (before the carbon fiber part) varied between 0.04 inches and 0.03 inches wider than the Red 2012.
    Apr 2010
    Well, I just ordered my Force 22 FD for my 10 spd Force shifters and crankset. I'm going to be able to run small/small all day now
    It's a fire road.............
    I'm on a road bike..........
    They have enough in common to blast down it.
    Apr 2012
    Quote Originally Posted by ziscwg View Post
    I have about 5,000 miles on my Force 22 Yaw FD (everything else Force 10) no issues.
    scott s.
    Apr 2010
    Quote Originally Posted by scott967 View Post
    scott s.
    The install was different than the norm, but I just followed the vids and poof, it worked almost perfect. I had to adj cable tension, but that was it.
    I can run small, small, but I don't.
    Reputation: BCSaltchucker's Avatar
    Jul 2011
    works no problem
    I just took off my Rival 10 frt and Rr Derailleurs and put on Red22 derailleurs. Retaining the Rival 10 shifters. much nicer!
    Now the front works MUCH better, more intelligently. Before I could access only the lowest 3 cogs on the small chainring Now I can access all 10 cogs in small chainring. This makes more sense, closer to how gears are traditionally used.
    Someone mentioned you lose trim function in the levers. This is nonsense. I still have trim on the big ring to help access more of the block.
  1. Replies: 1
    Last Post: 01-22-2016, 01:39 PM
  2. Sram Rival Brifters with a X7 9-speed rear mech...will it work?
    By ozbikebuddy in forum Components, Wrenching
    Last Post: 01-18-2013, 08:26 AM
  3. Replies: 5
    Last Post: 02-05-2012, 10:27 PM
  4. 10 speed SRAM Front Derailleur work with my 9 speed?
    By Gall in forum Components, Wrenching
    Last Post: 07-25-2010, 04:16 PM
  5. Will a SRAM Force Carbon crank work with my setup?
    By bseracka in forum Components, Wrenching
    Last Post: 07-20-2009, 10:22 AM
