Results 1 to 4 of 4
    Dec 2011
    Wired SRM models
    I'm in the market for a used BSA-compatible SRM, and I have a couple of questions I was hoping you might answer.
    What crankarms are used in the crankset below?
    Looks to me like they might be rebranded hollowgram crankarms, but I can't really tell.
    Also, are hollowgram cranksets bb30-only?
    Thanks!
    'brifter' is a lame word.
    those are 'SRM' crank arms, which was the only crankset available when the SRM system for came out. it wasn't until years later that SRM started working w/ other component companies (Shimano, SRAM, FSA, Campy) and building their system into other cranks. The are machined from billet aluminum and are not hollow.
    not sure what you mean by 'BSA' compatible as the crank doesn't care whether you bolt it to an English or Italian threaded frame and bottom bracket. there are 'cranks'...not 'english(BSA)' or 'italian' cranks.
    2010 Cervelo T1 sprint bike
    Ruger 10-22TD
    Smith&Wesson M&P 15-22
    Smith&Wesson M&P 9
    oh, those belong in another forum
    Dec 2011
    Thanks.
    To clarify, I am looking for a way to attach an SRM to my English threaded frame. As I understand, there are several types of SRM spiders, some of which (i.e. the early wired ones with bolt-on arms, and those sold with Shimano 7800 cranks) are assembled into crank sets which fit BSA-compatible bottom brackets.
    I say "BSA-compatible" because apparently some hollowgram cranksets can be used in English threaded frames with some effort.
    so what you need is any SRM using a standard Shimano Dura Ace crank, a SRAM GXP crank or the 24mm spindle (like SRAM & Shimano) FSA SRM. or a Campy SRM. you've got no shortage of cranks to chose from.
    Ruger 10-22TD
    Smith&Wesson M&P 9
  1. We are wired, aren't we?
    By nOOky in forum The Lounge
    Last Post: 05-22-2012, 10:04 AM
  2. Used Wired Dura-Ace SRM
    By WEG in forum Racing, Training, Nutrition, Triathlons
    Last Post: 01-14-2010, 11:41 AM
  3. wired or wireless
    By 2wd in forum Components, Wrenching
    Last Post: 11-17-2008, 11:45 AM
  4. Wired to Win
    By sbrsport in forum General Cycling Discussion
    Last Post: 07-04-2007, 06:52 PM
  5. Wired To Win
    By bill amc in forum General Cycling Discussion
    Last Post: 01-17-2006, 04:40 PM
Sea Otter Classic
Contest
