Results 1 to 5 of 5
    Reputation: PdxMark's Avatar
    Wrenching Oops - barend shifter removal fail
    Fitting an old Trek 520 for a different rider in the house I was going to put on wider handlebars. In removing the first barend shifter I couldn't believe how tightly it had been assembled. I tried so hard to loosen the interior mounting bolt that I stripped it. Then, on the other side, I realized that I should try to turn RIGHT to loosen the shifter. It was tight, but not that tight, so it came out fine... After continuing to maul the other one, I finally gave up and installed a parts bin spare on the new handlebar.
    Lesson: Barend shifters are removed by turning the mounting bolt to the right...
    'brifter' is a lame word.
    Quote Originally Posted by PdxMark View Post
    Fitting an old Trek 520 for a different rider in the house I was going to put on wider handlebars. In removing the first barend shifter I couldn't believe how tightly it had been assembled. I tried so hard to loosen the interior mounting bolt that I stripped it. then, on the other side, I realized that I should try to trun RIGHT to loosen the shifter. It was tight, but not that tight, so it came out fine... After continuing to maul the other one, I finall gave up and installed a parts bin spare on the new handlebar.
    ***if they're shimano***
    2010 Cervelo T1 sprint bike
    Ruger 10-22TD
    Smith&Wesson M&P 15-22
    Smith&Wesson M&P 9
    oh, those belong in another forum
    Jun 2007
    You are correct sir!
    Then it can be interesting if you don't put them together correctly.
    Ahhhh... That's why I don't remember the lesson from the last time I worked on barend shifters....
    Quote Originally Posted by Camilo View Post
    exactly...do NOT drop any bits or put them back together incorrectly...one of the biggest pains-in-the-butt ever!
    Ruger 10-22TD
    Smith&Wesson M&P 9
Sea Otter Classic
Contest
