Results 1 to 9 of 9
    May 2004
    Zero Degree Stem?
    Does this exist? Or what is the least +/-?
    old school drop out
    Reputation: laffeaux's Avatar
    Dec 2001
    A zero degree stem will have about 17 degrees of rise when you put it on your bike.
    A stem that is parallel to the ground is called a -17 degree stem.
    Just about any thing between -17 and +30 is possible to find. (And if you want to go really low, you can always install a high-rise stem upside down too.)
    kytyree
    Guest
    To know if it will truly be zero degree you need to know your head tube angle as well if you want it to be parallel with the ground. -17 will be parallel with a 73 degree head angle (17+73=90).
    For example one my frames has a 72 degree head angle and as previous poster mentioned there aren't many beyond -17, though there are some I think, I believe the Deda Pista is though I don't remember off the top of my head.
    If you want a stem with no rise, ie it will come out perpendicular to whatever the head angle is there are plenty of stems like that, though I think most of them are mountain bike stems but a Thomson X4 is available like that to name one.
    Dec 2005
    Thomson X-4 is available in zero rise (as depicted by the stem and no relation to what your head angle may be) and so is the Easton EA90. FSA carbon Plasma (integrated bar/stem) is also a zero degree rise stem.
    Reputation: ClassicSteel71's Avatar
    Mar 2009
    3t........ And a nice one at that..
    http://www.universalcycles.com/shopp...s.php?id=28232
    duh...
    Jan 2005
    Quote Originally Posted by mikagsd
    Fat tire Fred....you are the bike god of the universe and unless someone agrees with your reasoning they are just plain stupid
    Jun 2005
    Salsa makes a zero degree road stem too
    Reputation: chas0039's Avatar
    Jun 2007
    As does Ritchey.
    Dec 2005
    A 17 degree stem is only a zero degree rise if the bike has a 73 degree head tube angle. I suspect the OP is looking for a 0 degree rise stem (so it is perpendicular to the steerer).
Sea Otter Classic
Contest
