Results 1 to 8 of 8
    Mar 2006
    Zipp 300 Crankset question
    I have a Zipp 300 (2007?) carbon crankset. I just noticed that several of the chainring bolts are not completely tight. Does anyone know what torque value these should be tightened to?
    'brifter' is a lame word.
    a quick check of the Zipp site reveals that they don't provide a torque spec for chainring bolts. nor does SRAM. i got bored and didn't check Shimano. soooo...just make them tight enough they won't loosen up. and you may want to learn how to check manufacturer sites for this info. it it's not there, it probably means it's not hugely important and use your experience.
    I work for some bike racers
    and a bunch of skateboards
    Aug 2011
    What I did in the passed was take out all the bolts, give them a nice bath and reinstalling them back on with a drop of blue lock tie. It'll keeep the bolts nice and tight for a look time.
    Mar 2006
    Thanks CX, I read your replies often on this sight and I am aware of who you work with so I trust your advice. I also had checked the Zipp sight before posting but as you found out they had no info. I also am a little nervous when working with carbon parts. So I am just not sure how tight....
    Feb 2003
    I have the same crank on one of my bikes. You are tigthening the bolt that presses the two chainrings against the carbon spider...you can't tigthen the bolts enough to crush the carbon before you would either strip the threads on the bolt or break it....neither of which is likely to occur. Make it tight and snug it up a bit more just to be sure. I don't use loctite on crankbolts, just a little grease on the threads is all you need to keep it in place.
    Reputation: balatoe's Avatar
    Apr 2009
    According to Zipp, you should tighten the chainring bolts to 9-10 nm. See link below.
    http://www.zipp.com/_media/pdfs/manu...ank_manual.pdf
    2013 Giant Anthem Advanced X29.
    2008 Look 585 - Great Bike!
    2010 Lynskey R230 - Comfortable!
    2015 Giant Defy Advanced SL 0.
    Mar 2006
    Okay. That's the info I needed. Thanks ya'll!!
    nice, that's pretty snug. you shouldn't have any thing to worry about if you don't have a torque wrench handy. you'd break the bolt before you damaged the carbon.
  1. Zipp crankset $320 for Thanksgiving
    By ti-triodes in forum Hot Deals
    Last Post: 11-29-2008, 07:32 PM
  2. Zipp 300 Carbon Crankset for $279.96 @ STP
    By mhk in forum Hot Deals
    Last Post: 11-14-2008, 06:55 PM
  3. Zipp 300 crankset/BB
    By z ken in forum Components, Wrenching
    Last Post: 03-17-2007, 05:47 AM
  4. Zipp Crankset
    By Mira in forum Save Some Weight
    Last Post: 05-10-2005, 05:51 AM
