Results 1 to 1 of 1
    Reputation: PlatyPius's Avatar
    Feb 2009
    Zipp Vuka R2C Shifters - Tech Info
    I just got a tech update release from Zipp and thought I would share it here for anyone who does their own wrenching and has these shifters...
    There are 2 bolts on the Vuka R2C Shifters. One uses a 4mm allen wrench and one uses 5mm allen wrench. The 4mm
    bolt (see picture) is used to attached the shifter to the shifter boss for installation into an aero bar. The 5mm bolt is used
    to keep the shifter assembly in one piece. The 5mm bolt can be loosened to adjust the angle of attack of the shifter lever,
    but should NEVER be removed. Removing the 5mm bolt can cause the shifter to come apart, this will ruin your day. If you
    have disassembled the shifter please call Zipp’s technical experts. They can help you get the shifter back together.
    Other countries need to stop hatin' or we'll unfriend them. - Christine
    Apparently I left my reading comprehension glasses in my ass. - DrRoebuck
    Still, it felt great and I felt like I was sitting on some kind of vibrator -Touch0Gray
Sea Otter Classic
Contest
