Results 1 to 14 of 14
    vegan cyclocross disco
    Reputation: iamandy's Avatar
    Jun 2003
    Cable hanger on Wellens bike?
    Anyone ever see one of these for sale? I need to find one, my cable hanger needs a spacer between it and the headset cap and between it and the stem, but this seems like it would be perfect. I could cut about an inch off my fork using it. plus it looks like it has a sweet dial on it also! any help would be great. thanks - andy
    Reputation: bicyclenerd's Avatar
    Feb 2005
    Quote Originally Posted by iamandy
    do you have a bigger picture?
    Reputation: jeremyb's Avatar
    Jun 2004
    Quote Originally Posted by bicyclenerd
    you can kind of see it here (its gold)
    id be interested in this as well as far as where to get. it looks like bent piece of aluminum with a barrel adjuster on it as well.
    jeremyb
    PlusOneLap.com: Online Cyclocross Magazine
    NeoRetroGrouch
    Reputation: TurboTurtle's Avatar
    Like these? - TF
    http://www.nashbar.com/profile.cfm?s...142&PID=484346
    "Don't those guys know they're old?!!"
    Me, off the back, at my first 50+ road race.
    Aug 2002
    Looks like something made out of sheet metal then alodined or anodized. I guess you could try it if you have a drill, a sheet metal punch and a hand nibbler. Then, you could bend it to the final shape.
    lung lacking loser
    Reputation: beaker's Avatar
    Feb 2005
    IRD Long Drop?
    It doesn't look like it has quite the same drop as the one on Wellens bike, but if you are looking for extra room under the stem it might work
    http://www.interlocracing.com/cablehanger.html
    Now, IIRC you were workign on a gold project bike. If that's what you want it for (the gold color), you're out of luck since it only comes in black or silver.
    Jun 2003
    no bigger pictures, unfortunately...
    I have an almost identical version of the nashbar one. The problem is if I use no spacer the hanger can't sit flush against the headset cap. its an integrated headset and the cap is so wide that the cable hanger doesn't clear it, and sits on the headset cap at an angle. make sense? It looks like the IRC version would have the same problem.
    the frame is an airborne aluminum frame, and I'm trying to set it up with little to no spacers between the stem and headset.
    Jun 2003
    here's a pic of my setup:
    THANKS for all the suggestions btw...
    Jun 2004
    this is what cyclocrossworld.com told me: "That pic is from last year, but they seem to use the same hanger only black
    this year. I don't know who makes it. It looks very similar to the IRD long
    hanger that we have on our store. If you have any other questions please let me know."
    Obviously the amount of drop is similiar to the IRD long drop, but as iamandy said, the IRC hanger still requires a spacer to be placed underneath it, while the wellens one is flat.
    jeremyb
    jhr
    jhr is offline
    May 2002
    possible solution
    I remember having the same problem a few years ago with a cannondale bike/frame. I wanted to put the hanger right on top of the headset, but the headset was too wide and hit the underside of the hanger. I solve the problem by taking a dremel and grinding away some metal on the underside of the hanger (the one I was using already had a curved cutaway underneath the hanger arm). It didn't need a whole lot of metal removed. Depending on the size of the top cap and hanger you may be able to do the same.
    sorry for the poorly worded explaination.
    jhr
    Jun 2003
    duh! what a good idea! i didn't even think of that. so easy.
    yeah. the hanger just barely doesn't fit so a little dremel action should save the day.
    thanks. andy
    Jun 2004
    i emailed Fidea, Wellens' team, last week and got this reply:
    Jeremy,
    Thanks for contacting us via our website.
    I've contacted Bart Wellens concerning his brakes.
    He answered me by saying that his brakes-system is made by someone he knows. So it is not of any kind of an existing system.
    Hope I helped you
    Greetings
    Marc Caluw├ę
    Marketing.
    there you go, its bent aluminum plate from some guy in europe.
    jeremy
    Jun 2003
    dude! thats nuts! you just had a person ask the ex-world champ BART WELLENS (from Belgium no less!) about his cable hanger because a few dorks on a message board that race b's in the middle of nowhere USA like his setup. amazing! that made my day. thanks!!!
    how'd the conversation go i wonder?
    Jun 2004
    i know i just told my girlfriend the same thing. A guy asked the ex world champ a question i had and he didnt say top secret piss off.
    jeremy
