Results 1 to 4 of 4
Thread: changing fork
    Apr 2006
    changing fork
    I have a fork I want to swap because the brake pads don't open wide enough to insert a wheel with an inflated tire. Current rake is 45mm; I can get a good deal on a fork with a 47mm rake. I have a 60cm frame with a 74 degree HTA. What difference would I see going from 45 to 47mm?
    J-K
    J-K is offline
    Nov 2006
    Quote Originally Posted by teleguy57 View Post
    Is that HTA correct?? What kind of bike is that?
    If it is that steep, I would not add a single mm of rake. In case you do not know that: More rake means less trail, means a twitchier bike.
    Apr 2006
    The frame is Performance's house brand CX frame, Scattante XRL. It does have a 74 degree HTA in the 60cm coupled with a 72.5 STA.
    From what I've seen and ridden, at least on the road, a 74 degree HTA isn't at all uncommon in larger frames. Tends to keep the front end reined in. I'm finding the current config, 74 HTA with 45mm rake and a 120 stem to be very stable. I'm trying to figure out if the amount of change would be very noticable, or more fine tuning.
    J-K
    J-K is offline
    Nov 2006
    If it is very stable right now, the extra 2mm's will not hurt. I doubt if it is noticable.
  1. Changing fork rake
    By filtersweep in forum Fixed/Single Speed
    Last Post: 04-19-2010, 12:12 PM
  2. Question about changing out my fork
    By superflychief in forum Bikes, Frames and Forks
    Last Post: 03-16-2009, 10:48 PM
  3. Question about changing out fork.
    By superflychief in forum General Cycling Discussion
    Last Post: 03-12-2009, 05:15 PM
  4. Changing the fork on a Spec Dolce
    By CabDoctor in forum Bikes, Frames and Forks
    Last Post: 10-16-2007, 07:14 PM
  5. Changing fork...
    By scico in forum Specialized
    Last Post: 10-27-2004, 08:37 PM
