Results 1 to 10 of 10
    Reputation: KMan's Avatar
    Conti Twister Pro cross tires....how are these?
    I see these tires on sale for about $20 right now. How are these tires as cross tires? Are they worth it?
    I have used the twisters on a MTB tire and thought they were pretty good tires, definately were fast and offered a lot more traction than they look like they would have.
    Buy or skip (would used as a dry race tire and not on muddy days)
    KMan
    Is not a clown car
    Reputation: unclefuzzy_ss's Avatar
    Nov 2002
    Conti's have always had great rubber compounds for my taste. I haven't ridden these either, so I'd like to know too. I imagine they're pretty nice.
    Reputation: Pigtire's Avatar
    May 2004
    I use them
    Seems pretty stable in dry conditions but unsure on muddy situations. Overall I will use them again and I will take advantage of that $ 19.99 sale at Performance before it runs out.
    Jun 2004
    Something strange there. Performance lists them at 37c which is way HUGE for a racing tire. That's usually the absolute max size you can fit between chainstays on most cross bikes in fact. This tire normally is only 32c size. Is this a misprint by Performance, or is it a larger size that they are trying to get rid of, thus the lower price?
    May 2004
    The size listed is correct.
    That's the size listed on the sidewalls.It actually looks like a 38c and it barely clears my frame but I am not really worried about.
    rjw
    rjw is offline
    Jun 2004
    Quote Originally Posted by Dave K
    They come in 32c, 37c, and 42c.
    The 37c fit my Trek XO with plenty of clearance.
    Jun 2004
    Quote Originally Posted by Pigtire
    In that case, I'd say this is less of a racing tire, except for the roughest of courses, and more a general purpose off road tire.
    Sep 2004
    They run SMALL!
    [37mm on sidewall, 32 to 33mm measured with calipers at 3 bar. Nice tires for the rest!
    Dec 2001
    I use the 32's on my Pinarello...
    very nice, very fast on dry conditions (I have other things for mud) but they are incredibly heavy tires...something like 470 g for the 32's, and if iyour rims are just a little big, they are difficult to mount (incredibly strong and tight bead). I bought mine on sale locally for about that price and haven't regretted the purchase.
    Apr 2002
    Great tire!
    I have the 700x32 (really more like 28-30mm wide). Rolls almost like a slick on pavement, but has great grip on everything from pavement to gravel to slick mud. I should disclose that I've only used it as a rear tire, so I don't know how it works up front - and I've heard that the MTB version can be sketchy as a front tire, so caveat emptor.
    Mine is harder than most tires to mount, too. For some reason, every wire-bead Conti I've owned has a very tight bead, whereas every Kevlar-bead Conti I've had is ridiculously loose. Not a big deal for most people, but could be an issue if you also have rims that are hard to mount up, like Suns for example. The Sun-Conti combo can be quite difficult.
    Other negative is that it's pretty heavy. Mine's about 450g, which seems excessive to me for a tire of this width, even with a wire bead. I still put up with it because it's such a great tire otherwise.
  1. what size tires for turnint cross bike into pseudo-road
    By ritjobbie in forum Components, Wrenching
    Last Post: 09-02-2004, 06:48 AM
  2. are Conti GP3000 tires good for racing?
    By TrailSeer in forum Components, Wrenching
    Last Post: 08-27-2004, 10:15 AM
  3. Source for 37c Conti Twister Pros?
    By Vegancx in forum Cyclocross
    Last Post: 07-10-2004, 01:12 PM
  4. Conti GP3000 vs. Michelin Pro Race
    By soulsurfer104 in forum Components, Wrenching
    Last Post: 04-18-2004, 11:06 PM
  5. mounting cross tires
    By noavg55 in forum Cyclocross
    Last Post: 03-02-2004, 03:29 PM
Sea Otter Classic
Contest
