Results 1 to 4 of 4
    Jan 2006
    Easton EC90X Fork
    I have a 2010 Fuji CrossPro RC. It has a 1 1/8" Fork/HS that tapers into a bigger diameter on the bottom of the headtube.... Can I install a normal 1 1/8" Easton EC90X Fork on this frame???
    Jul 2010
    do you have this CX geometry?
    Jan 2003
    If you have a headtube that tapers from a 1 1/8" to 1 1/2", I would get the correct fork, not a straight 1 1/8". I believe Ritchey makes one, and know that ENVE makes one too. I would get the ENVE which is on sale on their site. But this assumes you have a headtube as above. I don't know Fuji's.
    Reputation: krisdrum's Avatar
    Oct 2007
    I don't think you can use a straight steerer tube fork on a bike with a tapered tube. Chris King might make a conversion kit, but I am assuming your Fuji does not have press-in headset cups, but an integrated headset.
    You don't want the Easton anyway, pretty flexy and is known to shudder under hard braking unless your brakes are set-up just right.
