favorite rims for cyclocross?
8K views 18 replies 12 participants last post by  biscut
#1 ·
What rims are recommended now for running 30mm to 40mm CX tires?
#5 · (Edited)
Kinlin XC279, with almost the exact same design as the HED Ardeness (see images below). It is the same width, and is a little bit deeper than the HED rim, so it should be a little bit stronger than the Ardeness (great for a rear wheel).
Kinlin XC279 Specifications:
-Weight- 490 grams per rim
-External Width- 23mm
-Internal Width-17.2mm
-Depth- 28mm
-ERD (Effective Rim Diameter)-584mm
-Material- Niobium/Aluminium
See comparison here:
Alloy Rim Roundup - Fairwheel Bikes Blog
KINLIN INDUSTRIAL CORPORATION | XC-279
Kinlin XC279 Rim Review - WheelBuilder.org
Line Parallel Circle Kitchen appliance accessory Cylinder
Text Line Drinkware Cup Circle
#8 ·
Ive been running HED Ardennes + for the past two seasons. I race and train on them in al conditions and they have been fantastic. Sub 1600g make them competitive with carbon but I'd argue more durable if you ride any trail or lots of gravel. For pure race wheels, carbon is awesome but for an all around, I love the HED wheels I use.
#10 ·
Any nice 29er wheelset in the 21 - 24 ID width range that somebody is selling cheap cause they're upgrading to wider wheels.
Carbon if you have the money and/or racing I guess, but alum is nice for that ideal CX pressure that allows occasional rim strikes. With alum I don't cringe as much as rim striking carbon and I can visually inspect the rim for dents (which I have yet to see in my alum wheels despite rim striking almost 1x a ride).
#11 ·
Hed Belgium Plus are hilariously overpriced, you can get comparable Kinlin rims for $100 less PER RIM. I have built up multiple sets of the Above Light Bicycle rims with BHS (Bitex) hubs and Sapim Laser spokes for under $700.00. That's what I'm running on my "gravel" bike now, Stiff, light (1450g), bulletproof.
#12 ·
They aren't cheap, but I wouldn't call the Belgium Plus overpriced. They are as laterally stiff as any wheel I've ridden (admittedly not that many), and as bombproof as they come.
I have 12k miles on a set that I started riding at 310lbs (down to 235lbs now). My personal opinion is that they are worth every penny, and then some...
#15 · (Edited)
Well, I just built some HED Belgium+ rims on Novatec centerlock disc brake hubs. Came out really well. My only complaint about this rim is it's not available in 24h. It's a very nice rim.
Since people like 24h, now I am building the last pair of Pacenti SL25 that I could find. After that, I already have Stan's Grail on the way, which is probably going to be my default 24h rim.
#16 ·
HED Belgium +, if you want a clincher rim brake. They build up beautifully, very round, and as stated are laterally stiff.
You can get them in 24 hole in rim brake, not sure if about non-machined sidewall. But I bet if you called HED (or had your shop) they would send you out some. I'm not a big fan or 24 hole disc wheels though.
I also like the cheap carbon rims for disc builds and I've got 2 or 3 sets of older Specialized Roval Control SL carbon MTB wheels pressed into gravel/cx training wheel service now. Those are also excellent and are very light.
#19 ·
Wanted to follow up my post...I received the Nox asym wheelset with DT 350 36t hubs. Hubs are loud but the set has been excellent. Very happy with it.
Side note, haven't used Stans for CX but they sure do know AL mtb wheels. Good people to work with too. If I was going AL I would be looking their way.
