Results 1 to 17 of 17
    Corey213
    Reputation: Corey213's Avatar
    Jan 2013
    First time riding Tubulars
    I've been trying out some tubulars and I am having trouble getting the hang of them. They always feel like they are rolling over. I've been trying the weight /10 + 5psi to start out. That puts me at 22psi. I start at 24psi and still feel like I'm bottoming out and rolling it over. Do I go up to 26psi? I know a lot of this all depends on the each person, just looking for some tips or hints from people or if someone is trying out tubulars as well and seeing how they are taking the learning curve.
    Thanks!
    Jan 2010
    what size are these? what weight are you? 170# I assume.
    what kind of use? CX racing? Gravel?
    22 psi? where on earth did you get that idea? sounds awfully low.
    There's sometimes a buggy.
    One.
    Corey213
    Jan 2013
    They are 33 FMB Slaloms. I am 170. I have heard before and read that you do weight / 10 + 5psi which would get me at 22. Maybe that would work for slop or a European rider but sounds like for me, you are saying 25+ may be better? Thanks Bikerjulio!
    Jan 2010
    I don't really have experience with running pressures that low. It was just my initial reaction. Wait and see what other opinions show up.
    One.
    Dec 2008
    Quote Originally Posted by Corey213 View Post
    I weight about the same. I usually start at 24 front 26 rear and adjust from there.
    How are you measuring psi? The little needle on your regular floor pump is likely not that accurate at those low pressures. I use an sks airchecker gauge.
    Jan 2006
    Way too low on pressure, esp if you have the non "pro" FMB tires. The regular sidewalls have less support and are very supple. That means they will fold over in the corners easily. Try 26 and see how it feels. You might even need to go up higher depending on your rim width and the nature of the particular course you're riding on. ie off camber downhill turns will folder tires more easily.
    pmf
    pmf is offline
    You should pump them up the the same pressure that you pump your clinchers up to. 26 psi? You gotta be kidding.
    Jan 2006
    There is no reason you should ever run handmade CX tubulars at clincher pressures. Unless you're possibly talking about tubeless clinchers and even then you can almost always run lower in the tubulars.
    Pretty much the main reason to run tubulars is for the ability to use lower pressures.
    26psi is a totally reasonable place for a 170lb person to start with. I could see him needing 28rear/26-27 front depending on riding style and course. But, more than that would surprise me.
    My small stature wife is in the very low 20s and even high teens at times.
    pmf
    pmf is offline
    Quote Originally Posted by Corndog View Post
    It's been years since I rode on tubulars. I used to borrow a set of wheels with a rear disc for time trials that had tubulars on them. Back then, in the stone age, the belief was that more psi = faster. Maybe I'm thinking different tubulars here. Is this a wide tire? The ones I used to use were 23R/20F. Yes. It was the stone age. Anyone showing up with 25c wheels would have been laughed at.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by pmf View Post
    It's the cyclocross forum. He's using 33c tires.
    No relevance to riding a time trial.
    Jan 2006
    They are CX tires, so yes they are wide
    33mm with handmade cotton casings.
    Even for road things have shifter as people realize high psi just bounces you around more. Lower pressure and a wider tire for road racing is the most common now days. a 25mm or 26mm on a wide rim.... mid 90's psi or even slightly lower.
    Corey213
    Jan 2013
    Great thank you everyone! I'll try it out there and see what happens. You're all the best!
    Not Banned
    Reputation: atpjunkie's Avatar
    Mar 2002
    I would take them up to 35 psi and then work down. Ride for a while at the higher psi so you can adjust to the new feel. Then reduce as you become used to them. They are going to squish some on bumps and corners, you just need to get used to it.
    one nation, under surveillance with liberty and justice for few
    still not figgering on biggering
    Corey213
    Jan 2013
    I tried 28.5 and that felt good. Then checked again after 3 fast laps and it read 27.5 in the rear and 26.5 in the front(let out a little too much air). That felt good as well. I think 27.5 or 28 may work for these fast and dry conditions right now.
    Not Banned
    Mar 2002
    that's fine psi
    just be careful with those tires are sticks and such. The sidewalls are prone to tearing on sharp things
    when it gets wetter /softer drop the psi. Lower the PSI
    Aug 2013
    I'm 185 and am running 28/30. Seems to be a good pressure. PDX's btw.
    JeffOYB
    Apr 2006
    Quote Originally Posted by ddave12000 View Post
    Every rider and course and tire-model and wheel/rim-type and gauge is different!
    I love tubies. I find they give a ski-like feel. They smear some. They take the buzz off, smooth things out much better than clinchers do. ...But you don't want to feel the tire flopping over. Smooth courses like higher PSI -- you don't always want to go as tubies might let you.
    Just use trial and error for yourself then remember how your numbers go with which conditions.
    I have a real pickle with my situation. I have a Joe Blow Sport pump and a new $15 Meiser gauge that reads up to 60 w a lot of detail around 30. Nice! I kinda thought my pump was reading high but it was consistent.
    I weigh 180 in full kit. I use 32mm tires (FMB, Challenge).
    I get a good feel with 30F/35R on the pump.
    ...But on the new Meiser gauge it's 20F/25R !!!
    Oh well, as long as they're consistent -- and they are -- and I remember to keep all the REALLY DIFFERENT numbers straight, I'm good.
    Just to brag, I also have 30mm Dugast Typhoons which I hear are good in mud. (I get great prices on hand me downs from more serious racer pals. So I have a fun collection of tires and wheels to glue!)
    BTW, I notice that the 30 tires risk foldover more so I have to bump em up a bit. I'm now testing them on 23mm rims rather than 20mm like I had tried already. They seem less inclined to fold over now. So rim width seems like to also be a bit of a factor!
    (PS: This looks like maybe a livelier CX forum than the one over at Bikeforums. Why, I see a World Cup thread here! Zero WC interest over there. Sheesh!)
  1. Replies: 0
    Last Post: 10-22-2012, 10:39 PM
  2. First time install of Tubulars and need help!
    By Nacracer in forum Components, Wrenching
    Last Post: 05-02-2009, 06:53 PM
  3. First Time Poster, Short Time Lurker, Long Time FGWGFIW
    By Glenn D. in forum Bikes, Frames and Forks
    Last Post: 01-01-2009, 09:56 PM
  4. Is it time time change my tubulars ? (PICS)
    By ED531 in forum Wheels and Tires
    Last Post: 03-31-2007, 03:37 PM
  5. How does riding time/effort on Mt. Bike compare to road riding?
    By dawgcatching in forum General Cycling Discussion
    Last Post: 06-25-2004, 09:12 AM
