Results 1 to 6 of 6
    Oct 2007
    Kelly Knobby X builds/crankset bb advice
    Posted a similar thread earlier...trying to see if I can get more specifics on what bb length works and what does not work. I have a Sugino/White Industries square taper crankset, a Ritchey two-ring cross type crank that requires a v1 octolink (so I'd need bb's for these and unsure of length to get) or a third option is a new Race Face Evolve mtn crankset.
    jrm
    jrm is offline
    Dec 2001
    112.5
    [for sure. 109.5s to short and 116.00 is to long
    Frites en Mayo Velo Club
    Reputation: cx_fan's Avatar
    Jul 2004
    You can get an XTR V1 bottom bracket from your LBS. The QBP part number is CR0973 68x112.5.
    This is your only option that I see from QBP with a Shimano BB.
    There is this one on ebay:
    Good luck with your build
    blog.fritesenmayo.com
    The time has come...HUP HUP HUP
    Nov 2008
    I am guessing that you have an earlier version with the curved chainstays? I run a regular road crankset on my knobby.
    you can email Chris kelly from his website: info@kellybike.com
    I think he still responds fairly well.
    Quote Originally Posted by jdg_
    Oct 2007
    Thanks for the replies. It looks like the ~ 113mm length bb will work best so I have ordered one and will try the White Ind/Sugino crankset on it.
    And, yes, it is the version with wider rear stays/135mm rear spacing which is a little bit of a pain when sourcing off-the shelf wheelsets etc but I got a great deal on the frame/fork etc.
    Feb 2007
    68/73
    Quote Originally Posted by cx_fan
    need to use (2) 2.5mm spacers on a 68mm bb shell.
