Results 1 to 18 of 18
    Jul 2013
    Looking for SSCX Disc Frame Suggestions
    I want to build up a SSCX Disc bike for cross season. Unfortunately, the two leading candidates are out of the running. The latest on the Traitor Crusade is that it will not be available until possibly October, and the On-One Dirty Disco is no longer listed on the US distributor's website.
    I am set on getting a disc bike which drastically narrows the field. The only other candidate I can find is the Civilian Le Roi Le Veut D'Lux which looks like a nice fit albeit quite heavy given it has a carbon fork and is approximately the same weight as the steel fork Traitor.
    Any other suggestions?
    I'd actually consider custom but for the fact that I want to have the bike built up and shaken down by the end of the month.
    Thanks in advance...
    Jul 2010
    Idiot at large
    Apr 2010
    A chinese carbon frame for a chino-cross bike?
    2010 Specialized Secteur Elite with the RBR not-approved Mavic Ksyrium Elite wheelset
    2009 Specialized Rockhopper Comp 29er upgraded to SRAM X9 with 1x10 and Stan's Arch EX rims and tubeless.
    2013 Cannondale CAADX-6 Tiagra with 9-speed SLX RD to run 11-32T cassette and Stan's Alpha 400 rims and tubeless
    and
    Some Burton snowboard setups, one with stiff ol' Camber and one with Rocker-Camber-Rocker
    Reputation: ms6073's Avatar
    Quote Originally Posted by tednugent View Post
    Damn, they snaked my paint design. Also, not to take away from the marketing effort, but that Fanatic 'CX2' is also marketed direct from China and can be ordered from Dengfu with custom paint for nearly half the price.
    There may not be an 'I' in team but there is a 'U' in suck!
    __0
    _ \ |_
    (O)/ (O)
    CX'er
    Reputation: bikerector's Avatar
    Oct 2012
    Pricey but has discs and can take a belt.
    Spot Brand Bicycles Product Page Mod Disc SS
    And then there's this one, which I know nothing about except it is a steel sscx bike with disc brakes
    Raleigh Bicycles Furley
    Reputation: sslos's Avatar
    Aug 2003
    Second the BEER EBB. I have one on my MTB, and it's the bee's pajamas. Or something.
    Los
    "My pit bike is a six-pack."
    -Hodala CX
    Aug 2013
    Iohannes fac totum
    Mar 2008
    Quote Originally Posted by GasX View Post
    What size?
    Feb 2012
    Genesis Bikes - Day 01 Discs?
    Other non-disc options at sscx.me
    But any disc frame should do if you looked at the On-One DD (I've built that one as a SS CX bike)
    Jul 2013
    Quote Originally Posted by 88 rex View Post
    What size?
    something in the neighborhood of 55cm
    Jul 2013
    Quote Originally Posted by sscx View Post
    I haven't seen a way to get the Genesis as a frame but I will look again.
    As fr your Dirty Disco - I love how it looks. My big challenge with a vertical drop-out bike is that I want to use the White Industries Double Double cranks so I can run a dingle speed. That would require a square taper eccentric bottom bracket which as far as I can tell does not exist...
    Reputation: krisdrum's Avatar
    Oct 2007
    Then do an eccentric hub instead, like the WI.
    karl j.
    Apr 2005
    Quote Originally Posted by krisdrum View Post
    +1 for the WI Eccentric ENO hub, then you can use practically any frame you want. I rode one SSCX for two seasons and 30 races. I found the trick to get good chain tension was a little light pressure from a 19mm cone wrench to rotate the wheel back/forward, then tighten the 6mm bolts in a couple stages, and you're good to go.
    Iohannes fac totum
    Mar 2008
    Hmmmm......mine may be a hair too big. It's a 56 cm top tube. It's currently in the jig though so won't be complete for another 2 weeks at least (including powdercoat). True Temper S3 head tube, seat tube, seat stays, chain stays and KVA stainless top and down tube. Paragon Rockers. All silver fillet brazed. Internal rear routing. No braze-ons at all. Fork will be Wound Up with anodized black parts. Pure SS CX race bike.
    If you are in any way, shape or form interested just give me a shout. It was to be my display and race bike but I can always make another for myself.
    Jan 2006
    How about the Crusade?
    http://www.traitorcycles.com/2013/Bikes_Crusade.cfm?Token={ts_2013-08-05_13:52:14}-afdc476afc9d9b2f-1E2B31E0-0C6D-9567-6713F077C052F221
    Jul 2013
    Quote Originally Posted by Corndog View Post
    Read the OP.
    It's not going to be available until at least October.
    Iohannes fac totum
    Mar 2008
    Just an FYI....pre-powder, this frame weighed in at 1636g. Could have been lighter had I not went with internal routing.
    Jul 2010
    Quote Originally Posted by ms6073 View Post
    Which model?
  1. SSCX disc - more options?
    By E 12 in forum Cyclocross
    Last Post: 10-26-2012, 12:28 PM
  2. Disc compatible tubular suggestions?
    By fishit in forum Cyclocross
    Last Post: 08-12-2012, 03:21 AM
  3. Recommend SSCX w/ Disc Brakes
    By Local Hero in forum Cyclocross
    Last Post: 05-01-2012, 08:41 PM
  4. Suggestions for lower-cost SSCX frameset?
    By MarvinK in forum Custom Builders
    Last Post: 11-19-2010, 03:58 PM
  5. Replies: 22
    Last Post: 04-23-2009, 12:50 PM
