Results 1 to 11 of 11
    now in philadelphia
    Nov 2007
    semi hard pack tubular cross tires
    I'm in the market. Any suggestions?
    lackey
    Reputation: Joshua Pattersnap's Avatar
    Apr 2007
    The Challenge GRIFO XS is worth checking out.
    Oct 2006
    i just raced suckerbrook (twice) on the XS in white. It was very dry, with alot of grass, and then a trail section with alot of nasty rocks, then a sand pit, and then pavement, finally a loose rocky gravel section. they performed very well, with amazingly good grip, in all those conditions. i was worried about the tiny side knobs vs. the pipistrello, and a freind runs those, and they are alot more supple, but these did the job very well.
    mind you, i was riding slow. YMMV.
    Jerry
    Close the door, its cold out!
    my blogness
    now in philadelphia
    Nov 2007
    Dugast is out of my reach Jerry! Thanks for the feedback. I am in Philadelphia now and the climate and terrain is certainly different from Portland Oregon.
    Jan 1970
    File tread seems to be the natural answer, but I have found that the tractor tread works well in all but the worst conditions. If the course is really dry and hard, a 34 can be nice as you can run it very low and carry a lot of speed with shock absorbancy of the larger casing. Otherwise a nice and supple 32mm gives good grip with minimal rolling resistance. I am giving some thoughts to running Vittoria's new high tpi tires on my main wheels with some fairly worn down Griffos on my pit setup.
    Oct 2006
    I had grifo 32 file tread next to Dugast 32 file tread next to Grifo 34 standard tread this weekend.
    The dugast 32 is alot fatter and of course a fair bit more supple then the (white, high tpi) grifo XS. The 34 is HUGE. Pippi is more like 33 I would guess. Right in the middle.
    If I had it to do over, I would have gotten the 34xs. Maybe. I dunno. I do like em large, though.
    J
    my blogness
    now in philadelphia
    Nov 2007
    I ended up with the 290tpi Vittoria EVO XG tractor tread. I considered the file tread but the tubular version of the XN model (file-tread) does not comes with the side knobs as the clincher version does and I can't rationalize the cost of the Dugast. (Can anyone?)
    I use the Vittoria XN clincher (which has the same the same tread design as the Dugast Pipistrelli) on a fixed gear and it wasn't the most supple or stickiest tires but I hope that the new casing helps in that regard.
    Vittoria EVO XG
    now in philadelphia
    Nov 2007
    side note -
    the vittoria xn clincher as seen on my fixed gear.
    the vittoria xn tubular
    Sep 2006
    I've got the new XN tubular and it does have the side knobs like the clinchers do.
    now in philadelphia
    Nov 2007
    what gives? am i missing somthing?
    Jan 1970
    no -- it is a model year difference.
