Results 1 to 8 of 8
    Aug 2005
    Singlspeed chainring on a 1x9?
    I just set up my flat bar cyclocross bike as a 1x9, and I'm thinking the 39t is too small for the road. Can I use a 42t singlespeed chainring in it's place? I don't need it to be pinned or have ramps do I?
    Do not touch the trim.
    Sep 2004
    Quote Originally Posted by big boy phil
    You'd actually prefer it not be pinned or ramped.
    Aug 2005
    Ok. Cool. Just so I know, why would I prefer it to be not ramped or pinned? Is there a performance advantage?
    Feb 2006
    1. Find the ugliest hill you would ride up,
    2. Kill yourself for 50 min so you have not much mojo left
    3. Find the toughest gear you can practically crank up that hill.
    4. Do the math to find the gear ratio
    5. Size the front ring to match this gear ratio in the lowest rear cog
    Spinning the fast stuff is better than walking the hills
    Reputation: Henri65's Avatar
    Nov 2008
    The pins and ramps are to make it easier for the chain to shift from chainring to chainring, if your running a single chain ring you don't need it to shift.
    huvia ja hyötyä
    Jun 2005
    For more emphasis... you definitely do not want the chain to budge from that ring
    If the ride is rough, you might want some sort of a guide to keep the chain on.
    Aug 2005
    Thanks for all the responses. I just wanted to make sure there wouldn't be any issues with the chain going side to side from one gear to the next on the cassette. Oh, and I do have an outer chain guide as well as a third eye chain watch on the inside, so the chain shouldn't be going anywhere!
    huvia ja hyötyä
    Jun 2005
    One thing: there's singlespeed rings in a couple of different widths. Don't get a ring that is too wide for your chain.
