Results 1 to 3 of 3
    Mar 2004
    What a differance
    20 #'s makes. Being basically a roadie that rides cross for a change up during the winter I've always run my tire pressure around 50#'s. Handling has never been that great in the loose stuff and I had to be very careful riding up grades approaching 20%.
    I run tubulars and over the last three weeks or so I haven't pumped up the tires.
    Both handling in the loose stuff and going up hill have improved 100%.
    Reputation: zender's Avatar
    Jun 2009
    It's also important to use a dedicated presta pressure gauge with a bleed that is accurate in the 20-40 psi range. Most pumps I've used with a pressure gauge made for road bikes just don't have good accuracy in the 20-25 psi range.
    A few psi difference on a road bike is unlikely to have a tremendous effect on your chance at a podium. But, in CX, one bad line in an off-camber turn that forces you to dismount and you're done.
    "Well, this one goes to 11" - Campagnolo Rep
    Not Banned
    Reputation: atpjunkie's Avatar
    Mar 2002
    Quote Originally Posted by zender View Post
    second the dedicated gauge with bleed.
    over fill then bleed to desired psi
    one nation, under surveillance with liberty and justice for few
    still not figgering on biggering
  1. whats the differance between 7850 and 7900 24cl
    By tv264@aol.com in forum Shimano
    Last Post: 06-10-2012, 01:52 PM
  2. Differance between a Daily Commuter and a Touring Bike?
    By William_25 in forum Commuting, Touring and Ride Reports
    Last Post: 09-21-2011, 11:30 PM
  3. Hey, what's the differance....
    By bculp72 in forum Cyclocross
    Last Post: 09-18-2007, 12:52 PM
  4. How much of a differance is 1.5cm...
    By los318 in forum Bikes, Frames and Forks
    Last Post: 11-17-2005, 01:32 PM
