Results 1 to 3 of 3
    Oct 2010
    '09 HELP!! Felt B12 - Fork recall and rear brake questions
    Just picked up this great frame - does anyone know if it needs a specially configured rear brake caliper since it sits behind the crank at end of chain stay? Looks like pulling arm may be restricted by seat tube
    Also, there seems to be a recall on fork for this frame- each time I call Felt customer support I get no where in their automated answer system and the number I am dialing is for this issue.
    Thanks!
    Reputation: Lou3000's Avatar
    Aug 2010
    I can't help you on the fork recall, you'll have to talk to Felt.
    As for the brake, it takes a regular caliper, but only certain ones will work. I believe the Shimano 7800 is the most common upgrade. There are some TRP brakes that fit too.
    "I'm a real athlete, I'm not trying to be the best at exercising." - Kenny Powers
    feltbicycles.com
    Reputation: wpcouch's Avatar
    Jan 2011
    s54chris,
    Take the bike to your local Felt dealer so they can contact Felt Dealer Support with the S/N. They can tell you if you have an affected bike, and, if you do, process the claim.
    __________________________
    www.feltbicycles.com - wilcouchatfeltbicyclesdotcom - Facebook -
  1. Rear Brake - 2009 Felt B12 (Tri Bike)
    By s54chris in forum Components, Wrenching
    Last Post: 12-02-2012, 07:59 PM
  2. Felt Recall
    By WI B16 in forum Felt
    Last Post: 07-28-2010, 03:35 AM
  3. Felt 2007/2008 F1X Fork Recall
    By bchuang in forum Cyclocross
    Last Post: 08-31-2009, 07:22 AM
  4. Recall of 07/08 Felt F1X cross bikes
    By Coolhand in forum Cyclocross
    Last Post: 08-20-2009, 11:44 AM
  5. Felt F1X Recall
    By Glynis27 in forum Felt
    Last Post: 08-11-2009, 04:04 AM
