Results 1 to 6 of 6
    Apr 2014
    2014 B12/B14 Tire clearance for 25mm
    Hi All,
    First post!
    I'm getting into Tri's and my first option for a tri bike is the B12 or B14 but given my weight and road conditions where I ride I would really like to be able to use 25mm tires (at least).
    So, is it possible to fit 25mm in the 2014 B series?
    Which other Tri bikes can take 25mm tires?
    If not possible then I might look into getting an AR5
    Thanks!
    Jul 2013
    You should post on the "Ask Felt" page as SuperDave does take the time to answer questions (he is the USA Rep).
    Otherwise, ask the people on Slowtwitch.com as those are mostly Triathletes and alot on there do have Felt bikes.
    3T Cycling
    May 2009
    Quote Originally Posted by ConomaBike View Post
    Hi All,
    First post!
    Thanks!
    Yes, you can use 25mm tires on the B12 and B14.
    I'm not a USA rep for Felt but I do work for the product development side of the company.
    If you don't have a road bike, I'd encourage you to go the AR5 route. A triathlon bike can be a bit more limiting. If you are just starting in tri you may find other activities you might enjoy that are better suited to the AR.
    The AR and B series frames have nearly equal aero properties with the AR5 offering better high-yaw performance as well as more nimble handling.
    -SD
    Jul 2013
    Quote Originally Posted by SuperdaveFelt View Post
    -SD
    Sorry for not getting it right. From my point of view you work with Felt, in the USA so hence you represent them in some fashion for the USA sector. But, if that is what you prefer I'll keep note of that.
    Thanks for the aero properties of the AR and B series. Me thinks if I ever I get near the limits of my body for speed/fitness work I might have to upgrade to an DA to eek out those extra seconds here and there. That is, if I can ever get approval to buy another expensive bike.
    3T Cycling
    May 2009
    Quote Originally Posted by loxx0050 View Post
    No problem. I work for the global brand, based in Germany with a R&D + marketing office in Irvine, CA. Our USA distributor is based in Buffalo, NY. They are two separate companies actually. I want to try help forum members understand the capacity in which I work. I can help answer questions about tire clearance, etc. but I need to enlist the help of my USA Sales colleagues to answer questions about availability or North American dealer orders.
    The extent of my ability to help is somewhat limited by my job's responsibilities.
    As for your "next" bike. The IA is the bike to get for free speed for club time trials and triathlons. The DA is really suited for those that need to maintain a UCI legal bike/position.
    -SD
    Oct 2017
    Hello,
    Is there someone that tried 25mm on b Series Felt TT bikes ?
    I ask Felt and they said it was at my own risk...
    Thanks
    Martin
  1. 2014 synapse alloy 105 - lack of heel clearance
    By drothman in forum Cannondale
    Last Post: 04-27-2014, 09:01 AM
  2. Tire clearance for 2014 Roubaix
    By Zampano in forum Specialized
    Last Post: 04-22-2014, 12:23 PM
  3. 3T Funda Fork 25mm Tire Clearance
    By Boltman76 in forum Cervelo
    Last Post: 12-01-2012, 12:34 AM
  4. Michelin pro race3 25mm no fork clearance?
    By samh in forum Wheels and Tires
    Last Post: 11-20-2011, 06:23 PM
  5. Can EPS fit 25mm tire?
    By CCRoadRider in forum Colnago
    Last Post: 11-12-2010, 08:50 AM
