Results 1 to 3 of 3
    Oct 2015
    2016 Felt ZW4 Disc Bike (and V series) Questions...
    Does anyone know what is the max tire width that would fit in a Felt ZW4 Disc bike? I'm looking for a gravel/adventure type bike, and was considering the V55 - it would probably be the perfect bike if it comes with a carbon frame.
    I've read in some articles that carbon frames are coming for the V-series. Does anyone know if the 2016 lines are locked down (which means carbon frames wouldn't come till 2017 at the earliest), or if it's possible that we'll see them in 2016? (I've asked the same question on the Ask Felt thread about this, but didn't get any responses). Any insight provided is greatly appreciated. Thanks so much!
    3T Cycling
    May 2009
    Quote Originally Posted by dooby View Post
    For a given price the Aluminum frame will deliver better overall value. You are not as concerned about ride quality when you can use 35mm tires at 35psi. The durability of an aluminum frame is also worth considering over carbon.
    The ZW4 will barely fit 27mm Challenge Paris Roubaix or Vittoria Pave tires. This is a road bike and does not have the tire clearance nor geometry of what has come to be described as a "gravel" bike.
    It's true that Felt is always innovating and developing new categories. I would be lying if I said you'd never see a V-carbon frame from us. Still, we do not carbon copy anything. We do our own development from ID, to 3D to carbon layup optimization so these projects can take a bit more time and seldom fall in a perfectly annual cycle. If you're buying in the next few months, take a look at the V55 or even the F4x with a cassette swap to the X01 cassette (10-42t).
    Cheers,
    SD
    #graveliswhereyouridenotwhatyouride
    Oct 2015
    Appreciate the response, SD.
  1. 2016 Felt FX Series
    By wpcouch in forum Felt
    Last Post: 08-27-2015, 07:46 AM
  2. 2016 Felt FX Series
    By wpcouch in forum Cyclocross
    Last Post: 08-26-2015, 09:26 AM
  3. Replies: 8
    Last Post: 08-19-2013, 07:44 AM
  4. Buying Felt Z series bike, couple of ?'s for SD
    By zach.scofield in forum Felt
    Last Post: 08-05-2010, 01:23 PM
